E4OD acting funny
Old Jun 18, 2018 | 12:54 PM
nomadw8's Avatar
nomadw8
E4OD acting funny
I recently purchased a 94' F-150. Its a 302, E4OD, 132,000 miles. I changed all fluids (engine oil, tranny, rear end coolant) soon after I bought it.
On a recent 500 mile trip I noticed the tranny would briefly ( a second or so) seem to shift into nuetral and immediately shift back into gear. This happened with and without O/D switched on. It happened maybe 6-7 times over the 500 mile trip.
No tach on this vehicle.
Any guesses on what's happening?
Old Jun 18, 2018 | 05:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My educated guess is that the Transmission Range Sensor (TRS) is failing. When it acts up it will send data to the PCM that you've moved the shifter from D to N. That causes the trans to shift to neutral. This is very, very hard to catch it in the act. I recommend replacing the TRS.
Old Jun 18, 2018 | 05:37 PM
nomadw8's Avatar
nomadw8
Originally Posted by Mark Kovalsky
My educated guess is that the Transmission Range Sensor (TRS) is failing. I recommend replacing the TRS.
Would this also cause the wild gyrations in the speedometer I'm seeing when speed reaches 55-60mph?
Old Jun 18, 2018 | 09:11 PM
Mark Kovalsky
No, but the wild gyrations in the speedo could also be causing the shift to neutral problem.
Old Jun 18, 2018 | 09:16 PM
nomadw8's Avatar
nomadw8
So how is the speedo cured of its wildness? The speedo is smooth from 0 - about 55. Then it starts gyrating up/down until I slow down to 50 or so.
Old Jun 18, 2018 | 09:37 PM
baddad457's Avatar
baddad457
Change the speedometer sensor on the top of the rearend and see if that cures it. Buy a new Ford sensor. The aftermarket units are junk. If you don't want to spring for a new one, get one out of a junkyard and try it.
Old Jun 19, 2018 | 11:06 AM
nomadw8's Avatar
nomadw8
OK.
Ford lists 2 different speed sensors for this truck.
1) MOTORCRAFT DY1205 - Located On Transmission
2) MOTORCRAFT DY1123 - Located In Rear Axle Housing
So which one do I need? Of do I need both? Amazon has them for about 40% off Ford's price.
Old Jun 19, 2018 | 11:09 AM
baddad457's Avatar
baddad457
Originally Posted by nomadw8
OK.
If you have an E4OD it's on the rearend. If not then you don't have an E4OD but an AOD or AODE
Old Jun 19, 2018 | 12:28 PM
nomadw8's Avatar
nomadw8
Thanks.Just ordered from Amazon. $24 including tax.
nomadw8
Jun 18, 2018 12:54 PM
nomadw8
Jun 18, 2018 12:50 PM
Chaos 95
Oct 17, 2011 09:11 AM
rob rosencrans
Jan 19, 2009 09:52 AM
