e4od Help!
Rob
A scanner with a data stream would be helpful at this point.
If you unplug the trans at the case connector it should start off in 4th, it will set all the codes but at least you will know that it is capable of another gear.
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
