Removing the tailgate
Old Jun 15, 2018 | 02:51 PM
meborder's Avatar
meborder
Just to be clear, you have to have it 3/4 way down to get the passengers side hinge off, then rotate vertical (with the first hinge off) to get the drivers side hinge. With it vertical, just pick it up under your arm and slide it to the passenger side to disengage the drivers side hinge.
that torsion spring helps A LOT to make it easier to lift. It's not any lighter than any other tailgate, just the spring helps A ton.
Old Jun 15, 2018 | 03:50 PM
tiny1's Avatar
tiny1
Moderator & CL
Mike is right, the torsion spring in the tailgate makes it A LOT easier to close. I can give mine a good shove when it is about half way up and it will close.
Old Jun 18, 2018 | 03:03 PM
Skeer's Avatar
Skeer
Thanks guys.. I'll try mine in an upright position later.
4x4pwr
Apr 9, 2023 04:31 PM
75BigBlock
16
Aug 22, 2017 04:07 PM
Vinford
Apr 20, 2015 12:52 PM
bigrigfixer
General Automotive Discussion
Jan 31, 2005 09:42 PM
Steverinoh
1997 - 2003 F150
Jan 7, 2005 04:03 PM
