P0304 misfire code
Old Jun 6, 2018 | 07:47 PM
ThirdsACharm's Avatar
ThirdsACharm
P0304 misfire code
I'm 700 miles into New sparkplug and boots on a 2011 ecoboost. Today at the tail end of my commute home, the truck couldnt accelerate, shuddered, and the pending code via my obdii reader was p0304.
I pulled the plug and checked the boot on cylinder 4 (first cylinder on driver side) but didn't see anything obvious wrong. I'll buy a new plug and boot tomorrow and see what happens. Anyone else see this sort of thing?
Side note, after putting evrything back together for the night the truck threw and ABS/check brake system code too. IM guessing vaccum pump because I noticed nearly no braking the first time I hit them recently, but I will take a look at that once the engine is back running right.
Old Jun 7, 2018 | 05:20 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
A similar thing happened to me after I changed plugs and boots. 7K miles after, the #2 coil went out. No issues since then.
As for the vacuum pump, it's under warranty for 10 years or 150K miles from Ford. Take to any dealer, they'll settle it for you.
Old Jun 7, 2018 | 06:15 AM
ThirdsACharm
Thanks Tseekins, I hadn't considered the coil may be bad. I'll replace that along with the plug and see what happens.
Old Jun 7, 2018 | 06:52 AM
ThirdsACharm
... while I'm waiting for the parts counter to open, I'm told the F150 doesn't have a vacuum pump by the service advisor. And that's why I do all the work I can on my own. SMH
Old Jun 7, 2018 | 08:32 AM
ThirdsACharm
I'm all set. She likes the new coil and plug. Thanks again.
Old Jun 7, 2018 | 05:01 PM
tseekins's Avatar
tseekins
I recommend you find another dealer then, it's under warranty and they'll fix it.
Old Jun 7, 2018 | 05:20 PM
ThirdsACharm
Eventually he did find it via VIN and was still a %%%% about it even after it stared at him in the face. So I won't go back there for the work. Hardly expect someone to know everything about every model year and model and component. But if I start the conversation, don't like being spoken to like I'm the idiot. Even IF I was wrong, just a bad customer service strategy. Now if only they'd order my headlight bearings...
Old Jun 16, 2018 | 01:40 PM
ThirdsACharm
Following the cylinder 4 misfire fix, I still didn't like how the truck was running.. It wasn't running bad, but it seemed a little lethargic.
Finally gave in and drilled the weep hole. Can't believe what came out of it. At 98k miles I bet most of you are wondering what took me so long. Just didn't think I had an issue until now, and this 1/16th hole seems to have fixed the issue.
Old Jun 19, 2018 | 05:17 AM
tseekins's Avatar
tseekins
Great news! The benefits of such a harmless little hole.
mtmcall
2004 - 2008 F150
Jan 16, 2016 12:48 PM
vectrex
1997 - 2003 F150
15
Jan 10, 2013 08:26 PM
al52269
Sep 14, 2012 08:44 AM
aa767man
Apr 19, 2010 09:28 PM
DavisMT
Nov 24, 2008 07:41 AM
