OBD2 help
Old Jun 2, 2018 | 09:21 PM
Josh Rowe Sr.'s Avatar
Josh Rowe Sr.
OBD2 help
2001 f250 and i can't connect to my obd connection with a scanner. truck won't start with scanner connected either. when you try to connect with truck running it shuts off. any help would be much apreciated.
Old Jun 3, 2018 | 01:51 AM
Shovelheadrob's Avatar
Shovelheadrob
What scanner? Most regular scanners can't read codes on our trucks anyway. They use a different protocol to later stuff. You either need a quality bluetooth module & Forscan or Torque pro (Forscan is better for diagnostics) or maybe someone in your area has this or AE?
Old Jun 3, 2018 | 09:59 PM
Josh Rowe Sr.
any recommendations on type of obd connectors?
Old Jun 3, 2018 | 11:20 PM
Shovelheadrob
I use the OBD2MX, it's not a cheap option, but it works, I initially tried a cheap Chinese cloned device & it did work but with very limited functionality.
Old Jun 4, 2018 | 06:25 AM
Tugly's Avatar
Tugly
Links in my signature get you there.
Old Jun 4, 2018 | 06:26 AM
Walleye Hunter's Avatar
Walleye Hunter
For android and PC devices you can get a bluetooth adapter, if you use iProducts you'll need a WIFI adapter. I use iProducts and have a VeePeak WIFI adapter from Amazon for around $15.00, it also connects to my laptop.
Old Jun 4, 2018 | 06:28 AM
Jaime74656's Avatar
Jaime74656
Link in my signature for Torque Pro faq also a good read if your relatively “new” to the obscure and these trucks, of links don’t show I will repost when I get home
Old Jun 4, 2018 | 11:02 AM
Tugly's Avatar
Tugly
Signatures don't insert when posting from the mobile site.
Old Jun 4, 2018 | 09:56 PM
Josh Rowe Sr.
Thanks guys! Just ordered a obd2 bluetooth and downloading Forscan as we speak. Will update once obd2 gets here.
slownsy
Aug 28, 2019 09:53 AM
steedpower
Oct 6, 2016 08:30 AM
Mike8623
Apr 12, 2016 02:36 PM
Brian Ski 44
Oct 11, 2015 04:07 PM
devolic
Jul 5, 2010 02:50 PM
