ignition switch replacement
Old Jun 2, 2018 | 06:13 PM
mr.badwrench's Avatar
mr.badwrench
Got a new set of door locks and keyed alike ignition switch for my 66. door locks were super easy to replace however the ignition switch is fighting me. From what I have read in the manual its just a push in and twist to remove, is it common for these to stick? I can twist it and can feel the little side pins unlock but it wont come out of the bezel. any advise would be greatly appreciated.
Old Jun 2, 2018 | 06:30 PM
Tedster9's Avatar
Tedster9
Well to be clear, you didn't mention the stiff paper clip part in the hole. You're doing that too, correct?
Then, I think it's turn all the way to the left, past ACC, and it should pull off.
Old Jun 2, 2018 | 06:33 PM
mr.badwrench
should have posted, I don't have the key for the switch currently in the dash.
Old Jun 2, 2018 | 07:15 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
With the key in and turned to ACC, insert a straightened paper clip into the hole to release the lock and remove the cylinder.
Old Jun 2, 2018 | 07:24 PM
AZSCAWPION's Avatar
AZSCAWPION
If you don't have the key you won't be able to rotate the cylinder for removal. It will have to be drilled out instead. Start with a small (1/8') bit and gradually increase. Drill maximum depth of 13/16" or else you will destroy the switch. Did it on mine a while back.
Old Jun 2, 2018 | 09:27 PM
6t6merc's Avatar
6t6merc
Or...give your old doorlock to a locksmith and ask him to make a key.
Old Jun 3, 2018 | 03:51 AM
Crop Duster's Avatar
Crop Duster
Lock cylinder
Absolutely the best way to do that if the locks still match. There is a number on the door lock that the locksmith can use to make a key. Take the one from the passenger side because that side doesn't get used much and is usually in good shape.
Old Jun 3, 2018 | 11:41 AM
daveengelson's Avatar
daveengelson
As noted, w/out the key assembly will have to be drilled out. I have never been able to drill out the key assembly from the damagine the switch, suggest replace both but recommend removing and inspect other components; bell shaped spacer, spring, bezel, etc. In addition, in the event decide to recondition the horn assembly best to order components at same time, particularly 'horn brushes' requires 2, one at the turn signal switch and the other inserts into insulator in the steering wheel, seem to recall replacement parts run $20-$30.
Once the key assembly has been removed hold the bezel from the front and press and turn the switch assembly from the back and pay attention in the order the components fit together. Take a few minutes and study how the key assembly fits into the switch, I found it best to install the switch then the key assembly, key should be in same position as it was when removed, ACC.
Anyhow, food for thought??[img]data:image/gif;base64,R0lGODlhFAAUAPEAAAAAAP//MwAAAAAAACH/C05FVFNDQVBFMi4wAwEAAAAh+QQFEgAAACwAAAAAFAAUAAECR4 SPqXviwpYINMDY7KQXO+Nw0tOBYrNVX9allcqa72yZ1xTSNYDz aviA9VwpItCnmxWRyd/K1SzJNMFTAsqBSaIe6ArDI2EKACH5BAkUAAAALAUAAgAIAAoAA QIPhC+HEWqRlIiu2osVfLEAACH5BAkUAAAALAUAAgAIAAoAQQI ThC0RkpwKlzioxUib2/Oq54FgAQAh+QQBFAAAACwEAAIACQAKAEECF4QvEqkc+2I6qMX7 KEiZeYBJSgg941MAACH+e1RoaXMgYW5pbWF0ZWQgR0lGIGZpbG Ugd2FzIGNvbnN0cnVjdGVkIHVzaW5nIFVsZWFkIEdJRiBBbmlt YXRvciwgdmlzaXQgdXMgYXQgaHR0cDovL3d3dy51bGVhZC5jb2 0gdG8gZmluZCBvdXQgbW9yZS4BVVNTUENNVAA7AA==[/img]
Old Jun 3, 2018 | 12:02 PM
mr.badwrench
thanks for the input, drilled out the old cylinder and got the new set in place. slowly but surely coming together. hopefully be back on the road soon!
Old Jun 4, 2018 | 11:10 AM
66with352's Avatar
66with352
I was missing the key in my donor cab for the ignition. Believe it or not, a you tube video of a kid (maybe 10 years old) explaining how to pick a lock, showed me to take a metal strip, bend it, and use to turn the cylinder to remove. He taught an old dog a new trick!!
brian1080
Dec 12, 2020 04:55 PM
brokersteve
Sep 19, 2012 07:54 PM
RedBoat
Jun 27, 2006 04:18 PM
Ed
Aerostar
15
Dec 3, 2005 08:38 PM
jcs1966
Nov 27, 2002 01:33 PM
