My remote start quit working.
Old Jun 1, 2018 | 08:33 AM
Les C's Avatar
Les C
I have a 2015 Ford F350, 4X4, Diesel. I went out this morning, like I usually do, I hit the lock and then I pressed the 2x two times. The horn beeped once, but the truck would not start. I tried both remotes.
Old Jun 1, 2018 | 08:37 AM
my_crib_too's Avatar
my_crib_too
Welcome to FTE! Is your check engine light on? Thought that the remote start would stop working if the truck had a check engine light on.
bruce....
Old Jun 1, 2018 | 09:23 AM
Just Strokin's Avatar
Just Strokin
Clear any DTC's and then try it. As Bruce said, remote start will not work if there is a code and CEL is lit.
Old Jun 1, 2018 | 10:09 AM
irly's Avatar
irly
hey mine has done that about 3 times in 4 years for no apparent reason, start it with the key and next time you shut it off and try it it should work fine, assuming there are no codes
Old Jun 1, 2018 | 01:12 PM
jav_eee's Avatar
jav_eee
I think if you don't turn it off under ideal conditions, like being in park when it's shut off, then it won't remote start the next time.
Also, a bad good switch can prevent it from starting too. Yours might be dirty or might've gone bad.
Old Jun 5, 2018 | 12:55 AM
1911fan's Avatar
1911fan
Mine did this when the check coolant additive message was active
Old Jun 5, 2018 | 08:50 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
The other thing you can try is to turn remote start off, start the truck with the key, then go back in and enable it again. That should clear the issue. Now as others have posted, if you have a code or warning it will happen again. Making the assumption that the hood is closed. If there are no codes or warnings might be the "hood closed" sensor.
JEB63
Jan 26, 2019 05:04 PM
wizard5861
6.7L Power Stroke Diesel
Jul 7, 2018 12:35 PM
WolfAK
16
Nov 22, 2015 10:06 AM
GORDEN1234
2009 - 2014 F150
Jan 20, 2015 10:20 AM
Seasprite
2004 - 2008 F150
Oct 18, 2007 09:32 PM
