Cranking No Start-- Updated/ Solved
Old May 26, 2018 | 09:59 PM
  #61
bismic's Avatar
bismic
Originally Posted by COVeteran
Comes with 1 year warranty so I could. It's a Delphi from AZ. I have help today since I'm one armed so bought what they had.
I understand that for sure. It (one hand) sure makes things difficult.
I know you probably couldn't afford the wait time, but the cheapest way to go for an OEM pump is below:
Racor PFP58054 FUEL PUMP ASSEMBLY - PARFIT
Other choices:
HFP964 - Delphi
AIRTEX Part # E2340
Spectra Premium SP114 - Rock Auto
None of them should be $300. Not trying to make you feel bad, just trying to help with the $$'s.
It is not a REAL common thing IMO, but unfortunately a number of people have been down the "bad pump" road before.
Edit - I just looked up Advance Auto's and Autozone's Delphi pump - $270. That is crazy expensive. I had no idea that they were that high for the pump alone.
Old May 26, 2018 | 10:04 PM
  #62
COVeteran's Avatar
COVeteran
Before i got the adapter, I could only confirm the pump was operating ny heating it. 52 psi today was confirmed with several koeo and each time I watched it drop back to 0. I don't have a hose big enough, I thought I did, but my brother put his finger over the fuel inlet onthe pump and felt the weak suction. There is more nothing registering on pressure tester.
Old May 26, 2018 | 10:05 PM
  #63
COVeteran's Avatar
COVeteran
Damn autocorrect, hearing the pump not heating it!
Old May 26, 2018 | 10:09 PM
  #64
bismic's Avatar
bismic
It is not unusual for the pressure to drop back to zero immediately when the key is turned off. It was the low initial pressure (53) that was the main problem w/ the original pump. It can jeopardize expensive injectors. Plus, the gurgling noise mystery needs to be solved I would think.
  #65
TooManyToys.'s Avatar
TooManyToys.
Drop back to 0 when? After some time without starting the PCM will time out the pump and the pressure will drop.
Old May 26, 2018 | 10:10 PM
  #66
COVeteran's Avatar
COVeteran
It dropped to 0 before key off.
Old May 26, 2018 | 10:11 PM
  #67
COVeteran's Avatar
COVeteran
It dropped as soon as pump shut off.
Old May 26, 2018 | 10:12 PM
  #68
FiznUKa's Avatar
FiznUKa
sloww typer it’s be said
Old May 26, 2018 | 10:16 PM
  #69
bismic's Avatar
bismic
How long will the pump stay on after first turning on the key?
Old May 26, 2018 | 10:17 PM
  #70
COVeteran's Avatar
COVeteran
It's a good 30 seconds.
Old May 26, 2018 | 10:18 PM
  #71
bismic's Avatar
bismic
As Jack posted, that is normal. The PCM is timing out and the pump shuts off when it does, Pressure dropping to zero when pump shuts down is normal also.
Old May 26, 2018 | 10:20 PM
  #72
COVeteran's Avatar
COVeteran
Well, I did something wrong then because the new pump is now 0.
Old May 26, 2018 | 10:39 PM
  #73
bismic's Avatar
bismic
Going back to pumping out of a bucket .... What size hose did you use and was it a sturdy "fuel line" hose, or a very soft wall plastic hose. If it is a small diameter clear plastic (soft wall) hose, it may be collapsing and shutting off. Also, could you confirm that it is running when 0, or that it is shutting off electrically prematurely.
Old May 26, 2018 | 10:45 PM
  #74
COVeteran's Avatar
COVeteran
I thought I had a hose but I didn't, so I wasn't able to do that test. I can hear the pump running and it's running for normal time. The pump itself is making a louder than normal sound. It's not the usual quiet hum.
Old May 27, 2018 | 01:59 AM
  #75
Euroman's Avatar
Euroman
Have I missed something, has the tank been physically checked for fuel? Easiest way to check is to brim it and then you're 100% sure
