Modular V10 (6.8l)
Hesitation in the 1500 to 2k RPM zone
Old 05-16-2018, 06:57 PM
Danny Ratliff's Avatar
Danny Ratliff
Danny Ratliff is offline
2000 F250 Lariat V10 179k
The truck has a miss in the rpm range and when it shifts to OD. The truck also seems to be running rich from the smell of the exhaust. There isnt CELs present and ive replaced the plugs with motorcraft plugs, New MAF, Air filter, ran 2 bottles of Seafoam in the tank.
things I plan on checking/ replacing next
PCV and hose, (elbow)
checking the resistance on COPS
cleaning the TB
replacing the fuel filter.
Any input would be appreciated. I really dont want to blindly throw money at it.
Old 05-17-2018, 06:36 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Does it run good at full throttle?
How bad is the misfire? Terrible or just kinda noticeable?
maybe you should get the engine codes pulled. Just in case your dash light is not working.
Old 05-17-2018, 07:43 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Get the misfire counters read and see if it's really a misfire. If it's a single cylinder, it could be the COP going bad or an injector plug coming loose.
Old 05-17-2018, 12:08 PM
Danny Ratliff
Seems to run great a full throttle and pretty rough at low rpms. There aren't any codes pulling up
Old 05-17-2018, 12:10 PM
Danny Ratliff
how is a good way to check injector plugs?
I'll have look into misfire counters also. Not sure how to go about that
Old 05-17-2018, 12:31 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Pull on 'em and see if they come off
The Android app Torque might be able to pull the misfire counters with an el-cheapo OBD-II Bluetooth adapter.
Old 05-18-2018, 12:05 AM
maticuno's Avatar
maticuno
maticuno is offline
Does the problem start when it's still cold first thing or when it heats up? Does it have trouble starting and idling at first? If you haven't at least thrown a code reader on it you should give that a shot to see if there are any stored/pending DTC's. Fine at WOT and rough at partial sounds like possible vacuum leak or O2 sensor.
Old 05-20-2018, 12:35 PM
EMC V10 X's Avatar
EMC V10 X
EMC V10 X is offline
Same issue and it went away when I replace all of the plug boots and one bad COP.
Old 05-21-2018, 03:52 PM
Danny Ratliff
Id hate to replace all of the COPS and that not be the issue.
Runs the same hot or cold
no codes pull up
new pcv hose and elbow
all injector plugs are connected well
Old 05-21-2018, 04:27 PM
rock2610d's Avatar
rock2610d
rock2610d is offline
Almost 20 yrs old and 180k, I would spend the $260 for new coils.
Old 05-21-2018, 06:03 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Been there done that. Don’t do it.
Im50fast's Avatar
Im50fast
Im50fast is offline
but then again; 20 yrs is very old.
Old 05-23-2018, 10:03 AM
EMC V10 X's Avatar
EMC V10 X
no codes pull up
I bought one COP and kept switching is around. I cant remember if it was 3 or 4, but definitely right side. Then I did ALL boots and plugs (200k miles) and it completely went away.
Old 05-23-2018, 10:24 AM
rock2610d's Avatar
rock2610d
I' glad you got it fixed.
But I have to be a little snarky.....
Why didn't you just try to find which plug or boot that was causing the issue and replace those?
I still say all new cops should have been done.
An extra $200 would have been good insurance.
Old 05-23-2018, 10:30 AM
EMC V10 X's Avatar
EMC V10 X
I was replacing the spark plugs anyhow. SO I just did them all. The current ones had at least 120k miles that I drove ti without replacement, And the truck had 80k on it when I bought it. They may have been original.
fomoco32
Modular V10 (6.8l)
02-06-2011 07:08 PM
wm070779
09-08-2009 01:13 PM
cpettymore7777
1997-2006 Expedition & Navigator
04-03-2007 04:44 PM
markvii91
Modular V10 (6.8l)
06-05-2006 07:10 PM
tankhokie
07-08-2004 12:15 PM
Quick Reply: Hesitation in the 1500 to 2k RPM zone
