engine miss
Old Mar 31, 2007 | 01:37 PM
cpettymore7777's Avatar
cpettymore7777
engine miss
98 expy 4.6. when crusing with no load i feel a miss in the engine. if a floor it it dont miss a beat. just seems without a load and under 2200 rpms. i had no codes. fuel pump and filter, mass air flow sensor and plugs are new. im out of ideas.
Old Mar 31, 2007 | 08:12 PM
ubereal2's Avatar
ubereal2
Have you given the TPS (throttle position sensor) a try?
It can give a miss in a given position in the throttle. Maybe one speed and not another.
Old Apr 1, 2007 | 07:56 AM
cpettymore7777
thanks, i will giver er a shot.
Old Apr 3, 2007 | 11:04 AM
Darth Baiter's Avatar
Darth Baiter
Plug wires shorting out? I had an issue with my 99 4.6 returning from a long winter trip in wet weather. Felt like I lost a cylinder, no codes, buck like mad under 2000 RPM but run much better with the OD off and RPM's at 2500 or 3000. Cleared itself on the way home. CEL flashed a few times but threw no codes. Took the local mechanic 2 visits to get it to miss. New plugs and wires (85K) and all's well again. I know you did plugs, how about wires?
Old Apr 3, 2007 | 04:38 PM
cpettymore7777
i didnt do the wires. they "looked good". i think i will give that i try. i tested the tps and thru the whole motion it passed.
Old Apr 3, 2007 | 04:43 PM
bigexpo's Avatar
bigexpo
coil pacls. thats what was wrong with ours and we replaced them and it worked perfect. READY TO TOW THE NEW 25ft DONZI
Old Apr 3, 2007 | 04:44 PM
66f25red's Avatar
66f25red
is it an automatic with OD? Could be the trans "hunting" if the speed is right on a shift point.
