Running Like Crap
Old Sep 7, 2009 | 07:37 PM
wm070779's Avatar
wm070779
Running Like Crap
I have a 1994 f-150 with a 5.8 that generally runs good. Here within the last few months it's been acting really strange. It has a 5spd and when going through the gears i've been noticing kind of a dead spot in the rpms range. It will climb rpms but very slowly and then all at once it will take off like a bat out of hell. I just replaced the tps on it today and it did no good . Any suggestions?
Old Sep 8, 2009 | 12:44 PM
Lazy K's Avatar
Lazy K
Are the plugs and wires good? How long since it had air filter and fuel filter. Might want to see if there are any trouble codes stored.
Old Sep 8, 2009 | 01:06 PM
wm070779's Avatar
wm070779
plugs were changed about april i'm going to try wires this weekend,fuel filter was last fall,and just cleaned the k&n last night. thanks for the ideas can you think of anything else just in case that doesn't work.
Old Sep 8, 2009 | 01:13 PM
Lazy K's Avatar
Lazy K
Try pulling any trouble codes that might be stored. If you don`t have a code reader go to fordfuelinjection.com and from the list on the right click on OBD1 self test for instructions on how to without one.
