Bronco II Ford Bronco II
Oil pump replacement
Old May 16, 2018 | 12:46 PM
1989bricknose's Avatar
1989bricknose
I was wondering if anyone here has ever changed the oil pump in a 2.9 liter. Mine is pretty much gone, and I'm getting conflicting info. I pretty much just need to know if I for sure need to pull the motor to swap it out. I've read that some people just drop the pan where it sits and pull it out of the way, but I've also seen some people saying that is like 100% for sure a way to mess EVERYTHING up. I'm just curious if anyone has any input on the subject.
Thanks!
Old Jun 30, 2018 | 06:23 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I bought an ‘89 B2 this past Fall and was told about a knock in the engine. I sloooooooowly got around to removing the oil pan after I got it running. You could probably replace the oil pump with it still in the truck but you’d be better off if you had the means to remove the engine.
As a side note : I gave up on this forum. There is very little if any input here. I asked a question about gauges being interchangeable with the 1st gen Explorer and never got a response.
3000gtman
17
Jan 5, 2019 03:16 AM
rudypoochris
Dec 20, 2006 11:41 AM
shortblock2000
Dec 12, 2006 05:17 AM
Weasel's_Truck
Jul 3, 2005 08:47 PM
ssayers
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 7, 2003 08:14 PM
