Replace oil pump
Old Sep 23, 2003 | 12:01 AM
ssayers's Avatar
ssayers
Replace oil pump
My 91 Explorer with 4.0L has been experiencing low oil pressure at idle after it's warmed up. I just had the oil and filter changed, but didn't help. I'm thinking it's the oil pump and would like to replace it. Do you have to pull the engine to pull the oil pan, or will the pan come off without pulling the engine. I'll be under my rig later this week but was hoping someone had an experience doing this. Thanks!
Old Sep 23, 2003 | 09:44 AM
mrshorty's Avatar
mrshorty
Replace oil pump
I don't know if anyone has ever succeeded in getting the oil pan off with the engine in the vehicle. The standard procedure for that is to remove the engine from the vehicle first.
Old Oct 7, 2003 | 08:14 PM
Blly177's Avatar
Blly177
before you try replacing the oil pump i would try using some 10w30 mobil 1 see if that helps also a motocraft filter i would also try some auto-rx
Casey Wright
1978 - 1996 Big Bronco
Mar 8, 2016 07:30 PM
JimJr15
Nov 2, 2015 03:33 PM
peka
Aug 26, 2015 01:51 PM
jrockdiddy
Jul 13, 2015 08:37 AM
tractormanbill
13
Dec 23, 2013 11:02 PM
