Fuel filter question
Old May 15, 2018 | 09:53 PM
jhinalabama's Avatar
jhinalabama
On my 2011 f150 3.5 ecb I cant fined the fuel filter. There is a black box of sorts mounted in front of the fuel tank that the fuel lines run in to. It doesn't look like it comes apart very easy. Is there a filter in it, or maybe a better question is what is it. My 2011 Expo has the same thing and I cant fined the fuel filter on it ether. I know the fuel filter is normal mounted on the frame rail. Thanks for the help.
Old May 16, 2018 | 06:25 AM
P.Bronner's Avatar
P.Bronner
Get eady to invent a few new 4-letter words.......
It's part if the pump assembly, inside the tank and not serviceable. Brilliant, eh ?
Old May 16, 2018 | 07:57 AM
Olytlr's Avatar
Olytlr
This has been standard on most all production gas powered vehicles for a couple of decades now. I couldn't tell you the last time I saw a separate out of tank fuel filter. Diesels on the other hand....
Old May 16, 2018 | 09:07 AM
Robbgt's Avatar
Robbgt
As mentioned, it is located in the tank. Are you having an issue that would lead you to believe it needs to be replaced?
From the manual:
Old May 16, 2018 | 10:12 AM
gDMJoe's Avatar
gDMJoe
Lightbulb
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
Old May 16, 2018 | 06:04 PM
P.Bronner's Avatar
P.Bronner
My '05/150 has an external filter.
Old May 16, 2018 | 10:29 PM
jhinalabama
From the manual:
No problems.. I'm just used to changing them at 100k
Old May 16, 2018 | 10:30 PM
jhinalabama
Thanks for all the input.
Old May 17, 2018 | 12:23 PM
gDMJoe's Avatar
gDMJoe
Arrow
P.Bronner - My '05/150 has an external filter.
F-150 external fuel filters became obsolete as of 2009. MEANING: 2008 was the last year for external, replaceable fuel filters.
Old May 18, 2018 | 12:37 AM
P.Bronner's Avatar
P.Bronner
I wonder if the average pump life is any longer with the fuel being filtered first? On the surface I don't like not having a serviceable filter, but I guess if the filter element can hold enough crap to outlive the pump its a non-issue.
sufferingant
May 13, 2010 11:29 PM
MartyMiller
Escape & Escape Hybrid
Oct 7, 2008 07:47 AM
SexyMF150
Apr 4, 2004 08:31 PM
Bronco86
Jan 2, 2004 01:45 PM
