Fuel filter question
On my 2011 f150 3.5 ecb I cant fined the fuel filter. There is a black box of sorts mounted in front of the fuel tank that the fuel lines run in to. It doesn't look like it comes apart very easy. Is there a filter in it, or maybe a better question is what is it. My 2011 Expo has the same thing and I cant fined the fuel filter on it ether. I know the fuel filter is normal mounted on the frame rail. Thanks for the help.
Get eady to invent a few new 4-letter words.......
It's part if the pump assembly, inside the tank and not serviceable. Brilliant, eh ? |
Originally Posted by P.Bronner
(Post 17986184)
As mentioned, it is located in the tank. Are you having an issue that would lead you to believe it needs to be replaced?
From the manual: https://cimg1.ibsrv.net/gimg/www.for...d11430f6cc.jpg |
http://www.gdmjoe.com/icons/lightbulb.gif (owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click- http://www.gdmjoe.com/icons/selectvehicle.jpg » Select Your Year [ Choose One ] » Select Your Make [ Choose One ] » Select Your Model [ Choose One ] » http://www.gdmjoe.com/icons/select-this-vehicle-50.jpg |
Originally Posted by Olytlr
(Post 17986334)
This has been standard on most all production gas powered vehicles for a couple of decades now. I couldn't tell you the last time I saw a separate out of tank fuel filter. Diesels on the other hand....
Originally Posted by Robbgt
(Post 17986473)
Thanks for all the input.
P.Bronner - My '05/150 has an external filter. . |
I wonder if the average pump life is any longer with the fuel being filtered first? On the surface I don't like not having a serviceable filter, but I guess if the filter element can hold enough crap to outlive the pump its a non-issue.
