U-joint question
Old Oct 13, 2018 | 10:03 PM
  #31
tazerproof's Avatar
tazerproof
I have had an OEM steering shaft end cap "bell"apart and posted pics..somewhere. It has a T end with 2 slip on square caps over a pin that goes thru the shaft.. T is red...squares are blue...the squares slide in 2 big grooves pressed in the bell.
I'm having the same issues with worn u-joints on my steering shaft and am having trouble removing it. I have the bolts on both ends off and the top end is loose from the steering column won't budge. The retaining collar spins around the shaft, but the shaft won't come free. Before I get too crazy with brute force or a cutting wheel, am I missing a trick or something? '76 F250 4X4.
HighboyMac
Nov 25, 2005 11:59 PM
Snowman671
Aug 19, 2005 01:26 PM
johnsonacres
Jan 17, 2004 02:11 AM
longview1
Apr 21, 2003 02:39 PM
