302 Distributor cap spark plug wire order
Old Oct 13, 2018 | 10:25 AM
clnilsen's Avatar
clnilsen
HELP!
I bought a new Distributor cap and plug wires, and when I was moving them over I discovered the 1 position was different than the one on the truck originally . In trying to move them back to the old cap, I lost the old order.
I've tried searching, but can't find what is supposed to be the right order for the plug wires for my engine (1978 302) I have found several different orders, but none of them seem to match what my truck actually was.
Any help would be desperately appreciated at this point.
Old Oct 13, 2018 | 10:29 AM
dlburch's Avatar
dlburch
1-5-4-2-6-3-7-8
when facing the engine...
number 1 cylinder is left front (then 2, 3, 4)
number 5 cylinder is right front (then 6, 7, 8)...
Old Oct 13, 2018 | 11:08 AM
clnilsen's Avatar
clnilsen
Originally Posted by dlburch
1-5-4-2-6-3-7-8
Thanks!!! My searching was failing miserably!
Old Oct 13, 2018 | 11:58 AM
FuzzFace2's Avatar
FuzzFace2
IF you have the stock intake is the fire order cast on it?
Only time I hear this may not work is if someone swapped in a 302HO or 351 cam then 2 of the wires get swapped just don't know what 2? but try the stock order first.
Dave ----
Old Oct 13, 2018 | 12:28 PM
meangreen92's Avatar
meangreen92
The cap should be marked to indicate which terminal post is #1. If you need to use any other post for the #1 cylinder, then the distributor is stabbed in incorrectly - at least a tooth off.
1-4 is passenger side. #1 is always the front cylinder of the bank which sticks out toward the front.
Small block Fords were always 15426378 until the 351W, which is 13726548. The 1982 and later 302/5.0 HO uses the 351 order.
Old Oct 13, 2018 | 06:00 PM
lafermedavid's Avatar
lafermedavid
same as my 460 15426378
Old Oct 14, 2018 | 01:59 AM
1TonBasecamp's Avatar
1TonBasecamp
...Only time I hear this may not work is if someone swapped in a 302HO or 351 cam then 2 of the wires get swapped just don't know what 2? but try the stock order first.
Yes to all of that. Except that it's actually 2 "pairs" or four wires. 5 and 4 and 3 and 7 get jumbled around to correspond to the different firing orders.
Paul
Ringwood1
25
May 29, 2026 03:19 PM
jck_strw
Jan 28, 2008 08:40 PM
bigox182002
3.8 & 4.2L V6
Jun 21, 2006 09:00 PM
Huntersbo
Apr 25, 2005 08:59 PM
duct tape F-150
Feb 9, 2005 01:28 PM
