steering shaft u-joint
Old Oct 12, 2003 | 08:59 PM
johnsonacres's Avatar
johnsonacres
My 71' f-250 4x4 has play in the steering shaft u-joint. How hard is it to replace? I've done regular u-joints but I don't see any clips or bolts on this set-up.
Thanks
Old Oct 18, 2003 | 12:11 AM
460EFIhighboy's Avatar
460EFIhighboy
I do not believe it is serviceable. I changed the whole shaft to aftermarket when mine went bad.
Old Oct 18, 2003 | 10:32 AM
jor's Avatar
jor
Are you sure the play is not in the rag joint? They are inexpensive and not difficult to repair. (not my own experience but lots of posts on this subject). Good luck.
jor
Old Oct 19, 2003 | 11:01 PM
460EFIhighboy
No rag joint on a F-250 4x4. they used a u-joint. Good thought though.
Old Jan 16, 2004 | 06:32 PM
orich's Avatar
orich
I replace mind 23 yrs ago,But first you need to find a replacement
.there is 1/2 moon clips inside. I'm was still good but the yoke slip joint was bad. So, I ended up getting after market $$$ ONE. There is a grease nipple on it. If greased will last a long time, Check steeling box for play. It can be adjusted to tighten it up. Maybe you can get one from a Drive line rebuilder.
orich
Old Jan 17, 2004 | 02:11 AM
Fordboy 72 F-100 4x4's Avatar
Try a Bugeson replacement shaft. There pricey but well worth it
1984F2506.9
Dec 4, 2014 11:32 PM
93f250tn
Aug 8, 2014 02:58 PM
2002exPSD
Jan 10, 2014 08:45 AM
Tomahawk2506
May 11, 2012 11:25 AM
mikev
Offroad & 4x4
Mar 27, 2004 10:26 AM
