Borg Warner T-85
Old May 10, 2018 | 11:14 PM
Troy_Lee's Avatar
Troy_Lee
Borg Warner T-85
Tell me more about the 3 speed overdrive transmissions, I have lined up one in a 1951 Ford Custom that has a 226 I-6, it is still in the car & from the pictures all the cables, and solenoids are still present. Of course, I'd convert it to from the 6 volt to the 12 volt for my 65 F100.
Aside from the lock-out cable, electronics, & the need to shorten the drive shaft, am I looking at any other changes?
Will this transmission bolt to my 352 FE?
Old May 10, 2018 | 11:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Troy_Lee
Tell me more about the 3 speed overdrive transmissions.
No, absolutely not!
No 3 M/T Overdrive of any year prior to 1965 will work.
1951 Ford has a flathead 6 w/a T-86 3 M/T with O/D .. NONE of the parts interchange!
T-85 with Overdrive: 1965/67 F100 240/300/352 // 1968/71 F100 240/300/360/390 // 1969/71 F100 302.
The O/D relay for these trucks is non existent.
Old May 11, 2018 | 10:55 PM
Troy_Lee's Avatar
Troy_Lee
Thanks ND!
I have a burning desire for an OD while keeping the column shift for sentimental value, but it seems the only viable alternative there is a floor shift 5. Auto just doesn't interest me.
Old May 12, 2018 | 04:35 AM
Crop Duster's Avatar
Crop Duster
T85
Thanks ND!
I have this stuff from my truck the PO said that the OD broke and he replaced it with a C6 back in the 1980's. He threw the T85 in the junk pile but didn't remove this stuff. Try car-part.com I looked on there and it seems there are a half dozen or so possibles listed. If you find a good trans and need any of this stuff PM me. Also Flashback F100's - Home you never know what he might have. Trouble with transmissions is they end up on truck freight and get expensive to ship.
Old May 13, 2018 | 02:07 AM
Boss9F100's Avatar
Boss9F100
I have the T-85 in my 1966 F100 Ranger and absolutely love it! Being my daily driver for just shy of a year would not trade for any other transmission for truck. I consistently get 20+ mpg local driving. With bone stock 352 it’s amazing how it will pull hills in OD with little effort. It’s running 35 mph per 1000 rpm or
3.5 mph per 100 rpm. Amazing stuff for being 52 plus years old.
Old May 13, 2018 | 04:03 AM
Crop Duster
Night shift
You must be working the night shift. I can understand that, I was stationed in AZ then flew there for a lot of years, too hot when the suns up!
What does that switch on the accelerator pedal bracket do?
Old May 13, 2018 | 04:08 AM
Boss9F100's Avatar
Boss9F100
accel switch is for kick down/passing gear.
If OP does not want to buy your extra parts I would be happy too.
Old May 13, 2018 | 04:42 AM
Crop Duster
Ok, We will see what Troy Lee come up with. They are yours if he doesn't want them.
Old May 14, 2018 | 09:06 PM
Troy_Lee's Avatar
Troy_Lee
Sorry for the delay, I must say I am interested in the brackets, I only find the time to browse here & there. I love the praise of the T-85 Boss!
Sam Vincent
Sep 29, 2016 06:56 PM
65 Ford F-100
19
Sep 24, 2014 01:15 PM
F-250 restorer
Jul 8, 2014 12:33 AM
DHCowdude
Apr 3, 2011 07:27 PM
frty7ford
Dec 5, 2009 11:14 AM
