Wiper conundrum
Old May 6, 2018 | 12:30 PM
John32369's Avatar
John32369
Wiper conundrum
The switch
From the motor
I have a 66 f100 that I bought that was missing some pieces, one of which was the wiper motor and bracket. I found one on eBay that was supposed to be from a 66 f350 and it fits. The only problem is that the connector on it doesn’t match the wiper switch in my dashboard. Can anyone help?
Old May 6, 2018 | 12:50 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The connector is of the type on the two-speed wiper motors. The switch is the type for the single speed wiper motor.
I'd believe you just need a switch for the two-speed wipers. A neat way to go if you want delay wipers also is to get the switch and governor from a later model Ford truck. Here's an example.
https://www.ebay.com/itm/Delay-Wiper...daCOVf&vxp=mtr
The black box is the governor, the loose wire is the ground. Your new wiper motor female connector plugs into the black male connector of the switch. The shaft would need a slight trim and an original **** and it's hard to tell from an original install.
Chad
Old May 6, 2018 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different 1966 two speed wiper switches. One has 4 terminals, the other has 7 terminals and includes the windshield washer switch.
C3TZ-17A553-E .. Two Speed Wiper Switch-4 terminals / Marked: C3TB-17A553-A or C3TB-17A553-E (Motorcraft SW-721) / Obsolete
1963/65 F100/350 and 1966 F100/350 before serial number 760,001 / 1963/65 F500/950 & N/NT500/850 and 1966 F500/950 & N/NT500/850 before serial number 802,001 / 1963/66 Econoline.
MUSTANG'S ETC. in Van Nuys CA has 1 = 818-767-7634.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
C6TZ-17A553-B .. Two Speed Wiper Switch-7 terminals - includes windshield washer switch / Marked C6TB-17A553-B / (Motorcraft SW-736) / Obsolete
1966 F100/350 from serial number 760,001 / 1966 F500/950 & N/NT500/850 from serial number 802,001 // 1967/69 F800/950 & N/NT500/950.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
Old May 6, 2018 | 05:17 PM
John32369's Avatar
John32369
Mine has 5 terminals it appears
Old May 6, 2018 | 06:06 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The wiper switch to wiper motor wiring connector is 5 (female) of the 7 total male connectors on the switch. 6th one is power from the ignition switch TO the wiper switch and the 7th one powers the wiper motor pump for the windshield squirters.
Chad
Old May 6, 2018 | 07:30 PM
NumberDummy
The only 5 terminal wiper switch is a single speed: C3TZ-17A553-G / Marked C3TB-17A553-G / Obsolete
1963/66 F100/600 & N500/600.
Old May 6, 2018 | 08:44 PM
John32369's Avatar
John32369
Any idea where I may find one?
Old May 6, 2018 | 08:50 PM
NumberDummy
Very hard to find, none have been available NOS for at least 8 years.
Old May 7, 2018 | 12:16 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Your wiper motor from the 66 F350 is the two speed motor so you'll want a two speed switch to go along with it. The connector from the motor isn't going to connect to a single speed switch.
Chad
Old May 14, 2018 | 10:38 PM
William's Avatar
William
Using the entire system off a later model Ford and the firewall bracket that you have (I suspect you have the right motor as well). You just need the later governor and switch. This is a plug and play up grade. Saw off a bit of the new switch and install a 66 button with set screw retainer (Carpenter has this). You will have a intermittent delay and two speed system that is not detectable until you turn the wipers on. Look on ebay for the complete system (switch, governor). Plug and play.
Nichalicious
Mar 20, 2019 05:46 PM
lindascott
1961 - 1963 F100 Unibody
Aug 2, 2018 08:58 AM
mr.badwrench
18
Jul 11, 2018 08:36 AM
tonkaman3
32
Aug 22, 2016 08:38 PM
ki0cn
Oct 20, 2009 05:32 PM
