Borg Warner Overdrive
Old Jul 5, 2014 | 11:46 PM
F-250 restorer's Avatar
F-250 restorer
Hello, guys, I'm hoping to get some information about the compatability of the T-85N with sbf, a 300. Is it just the bell housing that determines the application, I mean aside from the drive shaft length.
Thanks for all and any replies. k
Old Jul 6, 2014 | 09:06 AM
orich's Avatar
orich
Have you checked the net some info here's a link
Before you jump into getting one,
Orich
Borg Warner T-85N Overdrive Wiring Page
Old Jul 6, 2014 | 07:36 PM
orich's Avatar
orich
Old o/d tranny's there's not a lot of nos parts laying around when needed. So these are things to consider when doing a swap to yesteryears parts list. And if you don't know how to work on them is finding someone who would..
Orich
Old Jul 7, 2014 | 12:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
T-85N: 1965/67 F100 240/300/352 / 1968/71 F100 240/300/360/390 / 1969/71 F100 302.
All the parts are obsolete, the O/D relay is impossible to find NOS
Old Jul 7, 2014 | 02:46 PM
FECruzer69's Avatar
FECruzer69
Yes, you can unbolt a T-85N from an FE bellhousing, for example, and bolt it to a 302/351W bellhousing, or, for that matter, to a 400M bellhousing. Here's where it gets a little tricky though. Depending on the year of the tranny and the other bellhousing, the holes might not line up. The tranny to bell bolt locations were changed sometime during the early to mid-sixties. Some of the trannies were drilled for both styles of bells. If the trans only has four holes and won't line up with your bell, you may be able to drill the other holes. It would be a good idea to do some homework before buying anything.
As mentioned, parts are not being made for these trannies. They are a pretty tough tranny though and stand up well under normal use.
Old Jul 8, 2014 | 12:33 AM
NumberDummy
D1TZ-7505-D (replaced D1TZ-7505-C & C5TZ-7505-A) .. Bell Housing-Use with 3 & 4 M/T / Obsolete
1965/66 F100/250 2WD 240/300 / 1966 F100 4WD 240/300 / 1967/79 F100/350 240/300 // 1965/79 Econoline 240/300.
1969/79 F100 302 / 1975/79 F150 302 // 1966/68 Bronco 289 / 1969/77 Bronco 302 // 1969/74 Econoline 302 / 1975/79 Econoline 351W / 1979 E100/150 302.
1971/74 Ford/Merc Passenger Cars 351C.
hooterville
Jan 27, 2019 11:20 AM
Troy_Lee
May 14, 2018 09:06 PM
Daddyo's garage
Feb 7, 2013 09:14 AM
Unionite
Jul 7, 2011 03:33 PM
frty7ford
Dec 5, 2009 11:14 AM
