Overdrive
Old Dec 5, 2009 | 01:07 AM
frty7ford's Avatar
frty7ford
Overdrive
I am looking for a replacement speed sensor for my overdrive. I am not sure if I will be able to repair the wire that got pulled off of it. Thanks for the help
Old Dec 5, 2009 | 05:12 AM
jowilker's Avatar
jowilker
Hows about a little more info on what you have, brand, model if you have it. We don't know if it is original or has been swapped in from your post.
John
Old Dec 5, 2009 | 07:31 AM
banjopicker66's Avatar
banjopicker66
My guess is that your '65 has a T-85N model OD transmission. Look for the number on the side to confirm it.
The wire should be soldered to a contact - that's all. Pull the rubber boot to make sure.
That transmission was used in a lot of different models, not just Fords from '65 on.
It is also possible that the light duty version of that transmission used the same governor. I bet Bill (aka NumberDummy) can confirm that or not.
If you need to replace it (which I doubt), so, then E-bay may be your best bet. I just found 4 used possibilities, all less than 15$ each.
Old Dec 5, 2009 | 08:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Borg Warner T-85N 3 speed Overdrive, factory installed in: 1965/67 F100 240/300 I-6 & 352 / 1968/72 F100 240/300 I-6 & 360/390 / 1969/72 F100 302 / 1963/64 Galaxie 352/390 / 1965/67 Galaxie 352.
And...1951/56 Packard / 1956 Studebaker Golden Hawk (Packard V8 engine) / 1955/56 Nash & Hudson / 1956/63 Studebaker half ton pickups / 1949/51 Lincoln / And...et cetera!
There is no such thing as a speed sensor, so...my guess is...it's either the solenoid (mounted on the drivers side of the O/D unit) or governor (mounted atop the O/D unit) the OP is refering to.
Other maladies affecting this trans: The O/D relay is mounted on the engine side of the firewall, there is a fuse mounted on this relay.
There's a kickdown switch mounted adjacent to the accelerator pedal. The O/D cable can snap.
Some of these parts can be found NOS (New Old Stock) at Ford Dealers and Ford, Packard & Studebaker obsolete parts vendors.
btw: I have Studebaker & Packard parts catalogs, so I can list these part numbers too...if the parts cannot be found at a Ford related source.
Old Dec 5, 2009 | 11:04 AM
frty7ford's Avatar
frty7ford
Original 3 speed with overdrive, the governor is what i was referring tool. I am going to try to resolder the wire back on it was working fine before the trans was pulled. it just leaks out of the solenoid.
Old Dec 5, 2009 | 11:14 AM
NumberDummy
C5TZ6919A .. Overdrive Governor Assy / Obsolete / Fits: 1965/72 F100 w/T-85N O/D.
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
No other Ford Dealer, no obsolete parts vendor has any.
Kinsel will be cheaper, cuz 'ol Bob Allen wants mega-bucks for obsolete parts.
26H7693 .. O/D Solenoid Shaft Seal / Obsolete / Fits: 1965/72 T-85N O/D & Warner R9, R10 & R11 O/D's.
BOB ALLEN FORD has ONE.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
KLIMESH MOTOR SALES in Calmar IA has TWO = 563-562-3241.
JST AUTOMOTIVE in Lebanon TN has TWO = 615-443-3086.
ANTIQUE AUTO SUPPLY in Arlington TX has TWO = 817-275-2381.
donybrk
2004 - 2008 F150
58
Jun 27, 2007 03:32 PM
searsk
Nov 3, 2005 07:33 AM
bigbobe
Sep 21, 2004 01:51 PM
66fordf100
Aug 11, 2003 05:17 PM
inliner
Dec 19, 2001 06:26 AM
