Valve springs compressed tool...
Old May 9, 2018 | 07:40 PM
Jon143's Avatar
Jon143
What would you all recommend on valve springs compressors I was going to get the "universal one " at O'Reillys but I wasn' too sure... I want the best tool so I can do my valve seals the easiest way ...so can all yall give me some guidance and what tools will help me. ....since this is my first time under the valve covers on this truck... sorry for making a thread bout this... I couldn' find any information about it thanks again..
Old May 9, 2018 | 08:32 PM
ford390gashog's Avatar
ford390gashog
Are the heads on or off the truck?
Old May 9, 2018 | 09:09 PM
Jon143's Avatar
Jon143
Heads are on... just going to be changing valve seals
way easier if heads are off lol but I can' have her down that long lol hoping it will take a day or so to change them out
Old May 10, 2018 | 07:56 AM
Olds64's Avatar
Olds64
Old May 10, 2018 | 03:54 PM
Jon143's Avatar
Jon143
[QUOTE=Olds64;17975605]Jon, here is the type of valve spring compressor I've used before. Sometimes you can rent them from your local auto parts
ok thank you lot cheaper then O'Reillys lol it also looks fairly simple to
Old May 17, 2018 | 07:19 AM
hairyboxnoogle's Avatar
hairyboxnoogle
I bought the one harbor freight sells. Havent tore down my heads yet, but i did stick it on a valve to make sure it would and seems like it will work well. Was a little less than $20 and its the screw type.
Old May 19, 2018 | 11:13 AM
trobers2's Avatar
trobers2
I just pulled my 1st spring off with the Auto Zone loan a tool. This is the one I used:
Amazon Amazon
I might be having the same problem you are - my valve sills have become brittle and the plastic is flaking apart. Good luck!
Old May 19, 2018 | 02:24 PM
Chevy_Eater's Avatar
Chevy_Eater
I got that one as well. Haven't used it on an IDI, but I changed the valve seals on my 390 and it worked fine. Have to find a sweet spot for the hooks to grab the bottom of the springs without popping off, but got the hang of it after the first two or three.
Old May 19, 2018 | 10:12 PM
Charmalu's Avatar
Charmalu
https://www.amazon.com/OEMTOOLS-2704.../dp/B004FELIYY
Be careful with that tool, there is a warning.....LOL
WARNING:CHOKING HAZARD -- Small parts. Not for children under 3 yrs.
Be safe
Charlie
Old May 19, 2018 | 10:16 PM
Chevy_Eater
Be safe
Charlie
That's a good warning; I couldn't possibly add up the times I nearly choked to death on a valve spring compressor before I was three.
Old May 19, 2018 | 10:37 PM
genscripter's Avatar
genscripter
Be safe
Charlie
This is why I always play it safe, and never let my kids rebuild my heads until they are at least six years old.
Old May 19, 2018 | 11:31 PM
Tedster9's Avatar
Tedster9
Do they have that in a Gluten free organic version?
Ol'Red
Mar 17, 2009 01:05 PM
CheaperJeeper
Mar 9, 2008 01:47 PM
RawPower
Mar 8, 2005 10:21 PM
MaximumMax001
Jul 19, 2004 02:37 AM
