Pin Box clearance
Old May 5, 2018 | 01:45 PM
KWDAILYD's Avatar
KWDAILYD
Pin Box clearance
All you experts weigh in please. Got my new B&W slider installed today. Hooked to my 5th wheel for the first time and slid it forward and locked. With my tonneau cover locked all the way forward I have about 2 1/4 inches between it and the front of the pin box That distance is fine just not sure if it will clear when I turn. I don't really have room to back under at an angle where it is to see if it will clear. Just wonder if some of you have run into the same issues.
Old May 6, 2018 | 06:53 AM
senix's Avatar
senix
that is mighty close! I'd take the cover off, move the trailer to a location and put it back on. Then have a spotter watch is as you creep into a turn.
Old May 6, 2018 | 07:01 AM
acadianbob's Avatar
acadianbob
Looks really close. I'm surprised that you don't have more room than that. Is your rolltop a Retrax Pro? I have a Retrax and have way more room than that..
Is your pin over the axle? Or more toward the front? Is it the Ford puck system? I'm curious how your clearance got this short.
At least the rolltop is easy to remove . . . .
Old May 6, 2018 | 07:43 AM
KWDAILYD's Avatar
KWDAILYD
Yes, it is a Retrax Pro. I have the upriites on the hitch in the rearward position. Yes it is the factory puck system.
Old May 7, 2018 | 11:04 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If I were in your situation I would follow the advice of Scott (Senix) and replace parts as/if needed.
Old May 7, 2018 | 06:13 PM
backtrack2015's Avatar
backtrack2015
Your base is in backwards. The giant orange sticker goes toward the front I believe (or hope!). It's either you or me... I hope it's you!
EDIT: Just checked... see the RVK3370 instructions, your whole slider is in backwards. You'll need to swap it around and then redo the arm install.
Old May 7, 2018 | 06:28 PM
KWDAILYD's Avatar
KWDAILYD
Yep, figured that out not too long after I posted this. Shouldn't try to do things when your on meds. I've got shingles on my face and that alone messes with your concentration plus getting in hurry. Haven't fixed it yet, hopefully tomorrow. I figured it was something I did wrong. What gave it away for me was when I realized the lever for the slide was on the passenger side.
Old May 8, 2018 | 09:46 AM
GeorgeS59's Avatar
GeorgeS59
Good catch on the latch.
Old May 8, 2018 | 10:23 PM
KWDAILYD's Avatar
KWDAILYD
Swapped it all around today and it sure looks better. Thanks everyone for responding and not giving too hard a time!
REPO.
Apr 22, 2021 07:19 PM
brickman
All Things Towing
Mar 7, 2019 08:10 AM
BPofMD
All Things Towing
18
May 31, 2017 12:14 AM
mrpd114
All Other Items for Sale
Dec 8, 2013 07:01 PM
mel2000f150
All Things Towing
Sep 12, 2008 01:27 PM
