WHERES THE FUEL FILTER??
I have an 82 e350 6.6L. It is an rv. Im having fuel issues when coming to a stop, bogging down, if I don't throw it neutral and give it gas, it will stop running, bcap.. on open road, it runs. I've spent the majority of my day at autozone trying to get it running properly, also with there help trying to find the filter. No luck. As I've read in the forums, its on the carb or near it. Also the the pic of the fuel pump. I checked the pump and the filter that's attached to it, pump runs and filter is clean. I've cleaned the carb with spray carb cleaner. And I replaced, spark plugs, wires and cap.. Also what are the other issues I should look for if its not the filter or pump.? Thanks
