Cannot find fuel filter.
Old Nov 4, 2012 | 02:29 PM
c.langan's Avatar
c.langan
This is my first post. I am having a very hard time finding fuel filter and figured i should ask the experts. My manual says it should be on the fuel pump or carb. inlet. Most internet sources say the same thing but they both appear filterless. My truck is having hesitation problems on when driving but not sitting in neutral. It has 4 speed. I bought the two fuel filters that came up on the computer at autozone and cannot find anything that looks like either one. I posted pics of the carb, pump, and a thing that looks like a fuel filter but has a wire connected to it as well as the things i bought at autozone. Any insight would be a huge help because i am at a complete loss. Thank you.
Old Nov 4, 2012 | 02:31 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Aftermarket carb... so either you have inline filter between the pump and carb or somebody never installed one.
Josh
Old Nov 4, 2012 | 02:35 PM
c.langan's Avatar
c.langan
Thats what im starting to think to. Do you have any idea what else could be causing my hesitation problems? Timing was at 15 BTC and I adjusted to 6 BTC with no difference in hesitation issue.
Old Nov 4, 2012 | 02:39 PM
devino246's Avatar
devino246
Look down the throat of the carb with the engine off and open up the throttle. See two solid streams of gas shooting at the boosters? If not, either your accelerator pump diaphragm has hardened up, or the accelerator pump check valve has gone bad.
Old Nov 4, 2012 | 02:40 PM
Bullitt390's Avatar
Bullitt390
With no filter the carb is probably trashed inside, from accelerator passages, boosters, transfer tube, needle & seat... all of it.
For an FE engine I recommend 10-12 degrees BTDC with a stock engine.
Make sure the vacuum advance is hooked up (set timing with it disconnected though) , which I see a vacuum hose connected to the port, just verify.
Josh
c.langan's Avatar
c.langan
Yes the gas flows fine.
Old Nov 4, 2012 | 02:41 PM
devino246's Avatar
devino246
Regardless, it's rebuild time.
Old Nov 4, 2012 | 02:43 PM
c.langan's Avatar
c.langan
I was kinda thinking the carb was gonna need service anyway. Everything seems to point to a fuel issue.
Old Nov 4, 2012 | 04:06 PM
earthquake68's Avatar
earthquake68
Somebody put a Holley on your truck. It looks new enough, so it probably only needs a needle and seat if it needs anything. What it REALLY needs is for a person who knows Holleys VERY well to tune it to the engine. Holleys aren't like Edelbrocks. Just because it's brand new in the box, DOES NOT mean it's tuned to the engine. A hesitation off idle is a very common problem with Holley carburetors and it can be tuned out. Just don't take it to some yahoo that thinks he's a carb expert. Take it to someone qualified.
Old Nov 4, 2012 | 04:11 PM
devino246's Avatar
devino246
Hmm, one thing I just noticed: do you not have your choke hooked up?
Old Nov 4, 2012 | 04:20 PM
devino246's Avatar
devino246
No carb can be tuned to every engine out of the box, regardless of make. Holleys only have a few common adjustments: jets, accelerator pump cams, accelerator pump nozzles, and idle mixture screws.
Old Nov 4, 2012 | 04:23 PM
fmc400's Avatar
fmc400
MSEE
I saw that too. It looks like a manual choke that doesn't have the cable run. This will cause cold-start issues even with a carburetor rebuild and proper fuel filter.
Old Nov 4, 2012 | 05:09 PM
GLR's Avatar
GLR
A lot of Holleys have the fuel filter internally where the fuel goes into the carb. Disconnect the fuel line and remove the large 15/16" ??wrench size filter housing.
Click to View Details
Part Number: FF1100DL
Alternate Part Number: FF1100
Application: With external pump
Price: $3.99
STORE PICK UP
AVAILABLE
SHIP TO HOME
AVAILABLE
ADD TO CART
Old Nov 4, 2012 | 05:10 PM
GLR's Avatar
GLR
Fuel Filter | 1987 Ford F250 3/4 ton P/U 2WD 8 Cylinders L 7.5L 4BL | AutoZone.com
3rd one down
Old Nov 5, 2012 | 09:36 AM
earthquake68
They make different power valves, too. There's also the adjustment for the accelerator pump arm. Different weight springs for vacuum secondary pods, ....different metering plates for the secondaries. There's LOTS of room for adjustment in a Holley. Not only are all those adjustments there, but they can each be adjusted many different ways. Again, the flat spot off idle is super common and can be tuned out. I've only been tuning carburetors (specifically Holleys) for about 25 years or so, so I may just be wrong here.
The Edelbrock carburetors are more forgiving than the Holleys, is what I was trying to say. I think the Holley is a better carburetor because of it's tunability.
As far as the choke goes, yes it should be hooked up. Yes, it may have a slightly worse flat spot when cold. NO, it's not the end all, be all problem. I've milled plenty of choke towers off of Holley carburetors and still drove them with little issue cold.
rsh1966
Aug 13, 2018 10:50 PM
Ringoanny
May 4, 2018 06:27 PM
jgavac
Dec 28, 2017 09:13 PM
dthut
Jun 21, 2017 07:21 AM
RustFreeBucket
19
Jun 3, 2016 02:44 PM
