help!
Old Apr 27, 2018 | 10:53 AM
mrs griffin's Avatar
mrs griffin
help!
my truck jerks when I go on interstate or go up an hill, Whats wrong with it?
Old Apr 27, 2018 | 12:36 PM
P.Bronner's Avatar
P.Bronner
My first suspect would be the fuel filter.
Old Apr 27, 2018 | 01:31 PM
steve(ill)'s Avatar
steve(ill)
by "jerk" I would guess you mean stumble or buck... Most common problem is probably a misfire due to a bad coil (COP)... is there a little yellow CODE light lit on the dash ? IF so, you need to go to Auto Zone or other and have them read the CODE for free... then post here what that CODE is and we will tell you what the problem probably is
Old May 8, 2018 | 09:12 AM
redfishtd's Avatar
redfishtd
Classic misfires
When loaded or on overdrive misfires show up . You need plugs and new boots . You may have a failed coil on plug . Get codes downloaded at auto zone to see which ones . replace with real good quality . Aftermarket ones can damage your computer and are not reliable . You can clean all cop contacts real good as factory cops rarely fail .
If original plugs you may need to have lisle extraction tool on hand first . Read up on original plugs snapping off .
Onesprint
Mar 16, 2013 10:37 AM
stroken
Apr 24, 2009 06:11 AM
IneptMechanic
1997 - 2003 F150
Feb 8, 2007 12:09 AM
sbclemens
Dec 17, 2006 03:57 PM
dship
1997 - 2003 F150
Oct 14, 2002 11:49 PM
