OEM Clearance Lights
Old Jun 23, 2018 | 08:33 AM
  #46
bscooter99's Avatar
bscooter99
Sounds like a tech that doesn’t know what he’s talking about. There’s plenty that have gotten the one with the oem plug. I’d just follow the steps I had to take. That connector is available for purchase. I think I posted the part number as well
Old Jun 23, 2018 | 10:04 AM
  #47
Larryj's Avatar
Larryj
I'm ordering this kit today, In dire need of clearance lights on the F350.
Old Jun 25, 2018 | 05:45 AM
  #48
SCfire's Avatar
SCfire
When hen I called recon the representative initially said they didn’t have a harness with the plug, however he went to the back and found the harness with the plug and mailed it to me.
Originally Posted by TJP249
OK Folks,
So I ordered the RECON harness. Before ordering, I called RECON tech support and they confirmed what was mentioned above, and that all the new harnesses have the OEM connector and if I order from them that's what I will receive. well it showed up, and what I received had bare wires for the power source, no connector. I emailed them and now they claim there is no harness with a factory connector (and of course claimed most trucks don't have them). He said that I must referring to the connectors that attach to the lights, not the OEM connector in the A Pillar.
So, What am I missing? how many people have received a harness from RECON that has the mating factory connector for the connection in the passenger side A pillar? I can certainly work with the bare leads if necessary, but just confused by this whole thing.
Thanks
Old Jun 28, 2018 | 08:26 PM
  #49
TJP249's Avatar
TJP249
So I ran into another issue. I am using the Atomic LED lamps, and it turns out there is some sort of tolerance issue between the Atomic light heads, and Recon's harness. So I ended up tracking down the Ford factory harness (HC3Z-14335-DA). The connectors on the factory harness work perfect in the Atomic lamps, and of course has the factory A pillar connector, and the push pins to secure the harness in the roof panel. With a list price of 14.00 I am kicking myself for not going this route to begin with. I would recommend anyone adding lights just get the Ford harness.
If anyone needs a Recon harness PM me, will let it go for basically shipping cost.
kxriderforlife
Dec 24, 2018 11:56 AM
prangy89
Jul 18, 2017 09:06 AM
cbzdel
Mar 10, 2012 10:42 PM
erniek70
Oct 28, 2010 10:52 AM
voit1
Jan 20, 2003 11:57 AM
