Clearance Lights Install
Old Dec 23, 2018 | 08:10 PM
kxriderforlife's Avatar
kxriderforlife
I have searched all around on doing the cab light install on for my 17 with the moonroof and have found answers for almost everything. My only question is I ordered the lights from Recon with the harness. However, the harness came with a power and ground wire at the end of the harness. I have seen multiple others mention their harness having the connector to make this install wiring wise plug-n-play to the connector at the bottom of the passenger side pillar that has a dummy connector in it if the truck doesn't come with the lights installed from the factory. Since this harness didn't come with the connector, what is the easiest way to wire these lights up making sure they'll work just like they would from the factory meaning they come on anytime the amber lights in the headlights are on?
Old Dec 24, 2018 | 11:56 AM
FDNYL136's Avatar
FDNYL136
use the dummy connector
Naganalf
Sep 12, 2018 06:40 PM
86'F-150
Jan 14, 2013 10:48 PM
cbzdel
Mar 10, 2012 10:42 PM
emd160
6.7L Power Stroke Diesel
Jun 25, 2011 11:41 AM
Big Red 5205
Dec 27, 2006 03:40 AM
