Battery box cover
Old Apr 18, 2018 | 06:48 PM
Nitro1168's Avatar
Nitro1168
Battery box cover
I have a 56 that that right now I’m doing the metal work,and I’m wondering what you guys do with the battery box cover if you wanted to put carpet in. I was going to weld a patch over it but I didn’t know if I could still install the battery from underneath. Thank you for any replies
Old Apr 18, 2018 | 06:54 PM
CharlieLed's Avatar
CharlieLed
I believe that you will need to replace the OEM battery tray with a drop-down tray if you plan on eliminating the access cover...that's what I did on my 56.
Old Apr 18, 2018 | 07:34 PM
Nitro1168's Avatar
Nitro1168
Oh ok thanks I guess I’ll check with midfifty they probably have one.
Old Apr 18, 2018 | 09:10 PM
56panelford's Avatar
56panelford
You won't need access to your battery very often. I put remote battery posts on mine and a lead to plug in my battery tender..
Old Apr 19, 2018 | 07:58 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
John, I connect my battery tender to the starter solenoid and don't use remote posts for the drop down battery. I used a 98 Econoline aux battery box mounted to the frame. One thing to be aware of with a drop down battery is that it is extremely difficult to raise the battery box up into position with a large battery installed. You either have to have the vehicle on jack stands to raise it up or have a pit to work in. I am just not strong enough to reach out at arms length and raise 60 pounds with one arm. I actually have to use a floor jack to raise the box into position with a battery in place. Pictures of the box are in my gallery.
Old Apr 19, 2018 | 08:28 AM
Nitro1168's Avatar
Nitro1168
Thanks John, that’s good thinking about remote battery post.
Old Apr 19, 2018 | 09:31 AM
56panelford
I put the remote posts in just in case I ever needed a boost or need to help someone else out..
Old Apr 20, 2018 | 07:29 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
gregtx
Sep 16, 2008 10:30 AM
kunder54
Aug 22, 2007 01:40 PM
Caddy 53
May 1, 2002 07:26 PM
