Input Appreciated
Old Apr 12, 2018 | 09:23 PM
copsey's Avatar
copsey
Input Appreciated
My Excursion runs amazing when warm, however it’s only running on 7 cylinders when cold. By cold I mean anything with oil temp under 100 degrees. Scanned it tonight, only code aside from EGR (deleted) is a P0683. Ran a resistance check through the GPCM and all measured between .2 and .5 ohms. No contribution codes. I’m guessing I have a bad injector but why wouldn’t I get a contribution code for that cylinder?
Any idea why there wouldn’t be a contribution code? Going to run a parallel wire for the PCM to GPCM this weekend to eliminate that code.
Old Apr 12, 2018 | 09:50 PM
bismic's Avatar
bismic
What scan tool are you using?
Old Apr 12, 2018 | 09:54 PM
copsey's Avatar
copsey
Torque Pro on an Android tablet.
Old Apr 12, 2018 | 10:02 PM
bismic's Avatar
bismic
That should pick up a contribution code if there is one.
Old Apr 12, 2018 | 10:10 PM
copsey's Avatar
copsey
That’s why I’m confused. I’m sure it could be a glow plug just based on the symptoms but until I get the diag wire replaced I won’t know.
Old Apr 13, 2018 | 02:12 PM
WatsonR's Avatar
WatsonR
It doesn't really need a glow plug at that temp unless it's not delivering the correct fuel until it warms up and the other cylinders are compensating.
find someone with IDS or the clone and run the uncompensated test to really see what that hole is doing.
Old Apr 13, 2018 | 02:57 PM
Monster-4's Avatar
Monster-4
By 7 cylinders do you mean it's sluggish? You check your FICM voltage?
Old Apr 13, 2018 | 04:37 PM
69cj's Avatar
69cj
Did you check the ficm voltage?
Old Apr 13, 2018 | 04:58 PM
87crewdually's Avatar
87crewdually
You can easily have one or two lazy injectors and not have a code. The injector has to be dam near inoperable for a code to set alot of times.
Old Apr 14, 2018 | 03:20 PM
copsey's Avatar
copsey
FICM steady at 14, 14 and 48.5.
Truck isn't really sluggish but when it shifts to 5th and the converter locks you can feel one hole isn't firing. Almost a stutter in power delivery. i'd love to find someone local that knows what they are doing, haven't been able to find anyone with IDS that has a clue, including the local dealer.
Oil temps below 60ish degrees are when this occurs, runs perfect above 100 oil temp.
Old Apr 14, 2018 | 03:21 PM
copsey's Avatar
copsey
That's my guess. Will have to see about getting a knock-off IDS.
Old Apr 14, 2018 | 03:59 PM
Yahiko's Avatar
Yahiko
Also with the IDS and clone and I think Snap On you can run a glow plug check.
And yes I am getting ready to order things.
Old Apr 14, 2018 | 04:06 PM
87crewdually
. You're a little too far away. But what you describe is classic example of a lazy injector. The last 6.0 I worked on had 2 lazy ones on opposite sides. They wouldn't even chatter until warmed up. I put in fresh 5w40 syn and Hotshots Secret. After 85 miles of hard running they both came alive on a 40° cold start.
. Which reminds me. Can you perform a BUZZ test? You can use Forscan for this. Then if you don't hear an injector BUZZ in order then more than likely that's the lazy dead one.
Old Apr 14, 2018 | 09:23 PM
copsey's Avatar
copsey
Didn’t even think about the buzz test with Forscan. Can do that tomorrow morning. Truck should be cooled down enough to confirm. Does the buzz test run in order 1 through 8?
Old Apr 14, 2018 | 09:26 PM
copsey's Avatar
copsey
I should also add that I had the passenger side bank of injectors replaced about 20k ago. I’m hoping it’s not one of those but I should still be within the two year warranty if that’s the case.
