Intermittent Wiper Governor Problems
Old Apr 8, 2018 | 09:33 PM
zdneal's Avatar
zdneal
I have a 76 F250 and the wiper governor box is not working. I have pulled it apart multiple times, the first time it wasn't working the relay was welded to the top contact, so I fixed that and it worked perfectly time for a month and a half. Now it is doing the same exact thing again, but I pulled it apart and I looked over all of the contacts and tested continuity on everything and it was all looked fine. I put it all back together and it is still acting like it is just a standard system. If you turn it counterclockwise it all the way it will just go the same speed as it would in the standard low speed. I changed the switch and it also did nothing to it also. If you have any ideas on what it would be please tell me!
Old Apr 8, 2018 | 09:51 PM
75BigBlock's Avatar
75BigBlock
I'm not sure, but if all else fails you could hit up the JY for a box out of an 80's rig I'd imagine.
Old Apr 8, 2018 | 09:52 PM
meangreen92's Avatar
meangreen92
Could be a loose solder joint in the governator box. Might be a bunch of resistance somewhere which heated up and welded that relay?
Old Apr 8, 2018 | 10:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3TZ-17C476-A (replaced D1ZZ-17C476-A) .. Intermittent Wiper Governor / Obsolete
1971/73 Mustang/Cougar; 1973/77 F100/350. No Ford dealer or obsolete parts vendor has any.
D1ZZ-17C476-A =
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
Old Apr 9, 2018 | 10:46 AM
HoustonDave's Avatar
HoustonDave
Second meangreen's suggestion.... pulling the box apart is dead easy (two screws, I believe) and reflowing all the solder joints cured all my ills.
Old Apr 9, 2018 | 01:35 PM
zdneal's Avatar
zdneal
I've pulled the box apart and checked over all of the solder joints i cleaned up the relay and tested the continuity from between the wires from both sides of the relay so I think I am going to go to a junkyard and see if I can get one for cheap and make sure that its actually the box. I will post some pictures of it later today.
Old Apr 9, 2018 | 02:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You do know there are 2 different w/s wiper switches.
Twodifferenttypes of windshield wipers, twodifferentwiper switches. Two speed wiper switches have alow& high speed.
Intermittent (delay) wipers were optional on 1973/79 F100/350's and 1978/79 Bronco's. Intermittent isnotanother name for low speed!
DOOZ-17A553-A.. Two Speed Wiper Switch-Notused with intermittent wipers (MotorcraftSW-896) / Marked:D0OB-17A553-AorD/Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1970/71 Fairlane/Torino/Montego / 1970/72 Maverick/Comet.
SUSANVILLE FORD in Susanville CA= 530-257-2137.
NOS ONLY in San Jose CA = 800-667-6659.
WESLEY OBSOLETE PARTS in Liberty KY= 606-787-5293.
GREEN SALES CO. in Cincinnati OH= 800-543-4959.
D1OZ-17A553-A.. Two Speed Wiper Switch-Usedwithintermittent wipers (MotorcraftSW-1010) / Marked:D1OB-17A553-AA/Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
NOS ONLY
BURNS FORD in Burns OR= 541-573-7278.
GREEN SALES CO.
And D1OZ-17A553-A.. Two Speed Wiper Switch-Used with intermittent wipers (MotorcraftSW-1010) / Marked: D1OB-17A553-AA / Obsolete
DON'S TRUCK SALES in Fairbank IA= 319-365-2751.
MCDONALD OBSOLETE PARTS CO. in Rockport IN= 812-359-4965.
CARPENTERNOS OBSOLETEPARTS in Concord NC= 800-476-9653.
There are TWO different intermittent wiper governors. 1973/77 is one type, 1978/79 is another.
D3TZ-17C476-A(replaced D1ZZ-17C476-A) Intermittent Wiper Governor / Obsolete
Old Apr 9, 2018 | 02:32 PM
zdneal's Avatar
zdneal
Yes I know there is a difference but when I turn it counterclockwise like it will go into intermittent it acts like it is just in low speed as if I turned it clockwise one way.
Old Apr 9, 2018 | 02:52 PM
NumberDummy
D1OZ-17A553-A.. Two Speed Wiper Switch-Used with intermittent wipers (MotorcraftSW-1010) / Marked: D1OB-17A553-AA/ Obsolete
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 92 = 800-476-9653.
D3TZ-17C476-A(replaced D1ZZ-17C476-A) Intermittent Wiper Governor = See post #6
Old Apr 11, 2018 | 12:47 AM
black & blue 78/9's Avatar
black & blue 78/9
I pulled my intermitten switch and controller from an 84 pickup. Plug n play. Washer fluid even works.
Old Apr 11, 2018 | 02:56 AM
burnthelight88's Avatar
burnthelight88
Got mine out of an 84 bronco, again, totally plug and play. I have read about some who have to swap some sort of wire at the connector, but can't remember what circumstance dictates that you have to do that.
Old Apr 11, 2018 | 07:32 AM
mark-guiver's Avatar
mark-guiver
I had one do the same thing as yours once. It would work sometimes until it finally would no longer go intermittent. The dealer wanted some insane amount of money for a replacement that I couldn't justify. Took the box apart and found a broken wire on a capacitor on the circuit board. Sweated the capacitor off and took it to the local Radio Shack and found one that was very close to the same capacity (although it looked different). Sweated it back on and it was still working when I sold the truck. Cost 98 cents. Give the circuit board a close inspection and re-sweat the connections would be my advise.
Mark.
Old Apr 11, 2018 | 02:31 PM
zdneal's Avatar
zdneal
Well I turned it on high for a few wipes and then turned it to the slowest intermittent and it started working again yesterday. I have been using it all day yesterday and today and it is still working. I think I will go get one off of another truck anyway though just as a backup.
Old Apr 14, 2018 | 06:49 PM
Shawner1974's Avatar
Shawner1974
Hello everyone! I, too have been having trouble with my wipers. Sometimes the intermittent and low speeds will not work. High will always work. So when my wipers stop, I switch it to Hi for a few seconds, then back to low or intermittent...might work, might not. I replaced switch with the correct version, using dielectric grease on the connector, grounded to steel under dash. It did not fix the problem. Where is this governor located and do you think it might be my problem, or could it be the wiper motor? Thanks.
Old Apr 14, 2018 | 08:33 PM
1TonBasecamp's Avatar
1TonBasecamp
In both of your cases, it could easily be the switch itself, rather than just the delay module. Both of the situations sound very much like the ones I experienced where the wiper switch needed replacing.
Not sure if hitting the junkyard for a good switch is any better than new at this point in time (they're all going to be 40 years old at least!) but we generally consider old factory stuff that's working to be superior to much of the junk we get today from the parts manufacturer's China connections.
But could still be worth a try. Mine worked perfect, but that was 25 years ago when you arguably had a better chance of getting a good new part the first time.
Good luck to both of you. Just don't overlook the switch, while checking the modules.
Paul
normanm
Nov 15, 2018 06:48 PM
CK3
25
Oct 31, 2014 03:31 PM
jsnbuck
Jul 9, 2012 09:34 PM
Villagemonkey
Nov 6, 2004 08:25 PM
acesand8s
Oct 28, 2004 11:54 PM
