Wiper problem
Old Sep 27, 2009 | 11:43 AM
CK3's Avatar
CK3
Wiper problem
The wipers on my '91 F250 will only work on high & will not park. I replaced the in dash switch.. Pulled the motor apart & tried the posted "Fix" that's on the forum. I pulled a motor out of my buddies Fox Mustang & swapped it & they still do the same thing. Anyone have any ideas?
Thanks,
Carl
Old Sep 27, 2009 | 12:00 PM
quicklook2's Avatar
quicklook2
the wiper box behind glove box is the culprit.
Old Sep 27, 2009 | 01:10 PM
CK3's Avatar
CK3
What's the technical name for it? Can I buy an aftermarket one (parts store) or is it a dealer item? Anyone have a pic of the box? ... Thanks
Old Sep 27, 2009 | 01:34 PM
quicklook2's Avatar
quicklook2
dealer part or junkyard.
ford variable speed wiper box thingy.
Old Sep 28, 2009 | 05:52 PM
CK3's Avatar
CK3
bump...........
Old Sep 28, 2009 | 06:00 PM
BCHauler's Avatar
BCHauler
I thought it was refered to as the windshield wiper control module.
Old Sep 28, 2009 | 06:42 PM
CK3's Avatar
CK3
Anyone have a part number for it? I can't find anything online for a windshield wiper control module for the F series..
Old Sep 28, 2009 | 08:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try intermittent wiper governor Ford # E9TZ17B476A fits 84-91 F150-450...
AKA Motorcraft SW 2259.
Hope this helps...
Old Sep 28, 2009 | 08:26 PM
redlightning93's Avatar
redlightning93
Hope this helps...
A local JY item.
Old Sep 28, 2009 | 08:35 PM
CK3's Avatar
CK3
Hope this helps...
Thanks for the help....
Is this what it looks like?
Does it plug into the wiper switch on the dash?
Old Sep 28, 2009 | 08:40 PM
CK3's Avatar
CK3
Originally Posted by redlightning93
A local JY item.
It's only a $71.00 part new.. All the JY ones are as old or older than mine. Just not worth the hassle getting a used one & having it take a crap in the middle of winter..
Old Sep 28, 2009 | 09:31 PM
F150xlt's Avatar
F150xlt
Usually it's a cold solder joint on the circuit board inside the module you posted. The solder joint cracks at the large heat sink that has a diode mounted to it. Also I've seen a cold solder joint on one of the electrolytic caps.
If you follow the harness from the wiper switch it goes to the wiper delay/control module. It's held in place by a small bolt near the emergency brake release lever. Removing the driver side kick panel can help get better access to the bolt.
Old Sep 29, 2009 | 02:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, that's it! (and yes it just fits between the 3 position switch and the harness)
As F150xlt said the solder joints break. I have fixed them but never had a repair last long.
It's a PITA to get to on my truck so after fighting with it the first few times, I've just left the bracket off and wrapped it in foam rubber stuffed up under the dash.
Old Sep 29, 2009 | 10:37 AM
F150xlt's Avatar
F150xlt
That's a good idea NOT to reinstall it on the dash support bracket.
Probably only people who use the emergency brake have this problem.
I believe the solder joints crack because every time the emergency brake is released, the cable mechanism transmits a force/vibration which is transmitted to the control module circuit board,
I'd guess people with auto transmissions who don't use the emergency brake
don't have this problem.
Old Sep 29, 2009 | 11:28 AM
Alvin in AZ's Avatar
Alvin in AZ
brake don't have this problem. :)
Cool thinking! :)
Back in the 70's a friend had a '76 F350 cattle hauler and his emergency
brake lever hammered so hard on it's upper stop, so many times, when
released the lever went up higher than normal. :/
Right after I noticed that I started putting my foot on my '75 F150's
emergency pedal when I released it. :) It's such a habit I don't even think
about it and in those situations where I have -all my feet- on brakes and
clutches and gas pedals and then need to release the emergency brake
too, I have to think about not putting my foot on it. LOL :)
That habit has carried over to my '91 F150 XLT Lariat I inherited.
Alvin in AZ
