7.3l knock? Help
Old Apr 18, 2018 | 06:37 PM
  #31
Mikefrfd's Avatar
Mikefrfd
Okay yea it have the
Originally Posted by Hussler
Mike, I believe the hole is there for mechanical pump but no cam lobe to run it. If the pump is not connected in anyway you can remove it and plug the hole. That's what we do when converting to e-fuel.
Nothing wrong with SD fuel pump and SD fuel bowl filter combination. The SD's use a different style bowl and the look is pretty obvious, if that's what you have. Not trying to beat a dead horse here if your not interested but I'll see if I can find a picture if requested. Also the SD fuel plumbing is different where rear head ports are dead headed instead of fuel pressure supply lines. This causes injector #8 to knock and is normal (engineering bo-bo) because injector #6 and #8 fire sequentially causing some fuel starvation on injector #8. There are some fixes for it though.
okay it has the 99 pump, and yes no lobe. But 97 fuel bowl. Wish is I think part of the issue
Old Apr 18, 2018 | 06:42 PM
  #32
Mikefrfd's Avatar
Mikefrfd
And thanks for all the help. I've been super busy with work, so I haven't even gotten to drive or work on the truck. Dawn to dusk just about every day. But yea it had the 99 style pump, but the 97 bowl. Not sure about the lines. I don't know what to look for.
Old Apr 22, 2018 | 10:39 AM
  #33
Mikefrfd's Avatar
Mikefrfd
Uh helllo
is anybody out there😂😂😂😂
Old Apr 23, 2018 | 07:55 AM
  #34
Jarrett Campbell's Avatar
Jarrett Campbell
Do you have filters on the frame rail? Do you have fuel in your filter housing in the valley?
I have all the parts for you to put this back to stock if you want that. Sounds like you have a Frankenstein efuel setup that is going to be problematic in the future.
Old Apr 24, 2018 | 10:37 PM
  #35
Mikefrfd's Avatar
Mikefrfd
It can't go back to stock. There's no fuel lobe. It's a 99 block / cam.
Old Apr 24, 2018 | 10:39 PM
  #36
Mikefrfd's Avatar
Mikefrfd
And it uses the 97 fuel bowl. Does anyone know of any guys with an AE scanner in south jersey
Old Apr 25, 2018 | 07:56 AM
  #37
Jarrett Campbell
Understood. Sounds like you should probably get to looking for a E99+ fuel bowl to complete the swap out. And a 7/8" freeze plug to get that fuel pump out of there.
Old Apr 25, 2018 | 08:10 AM
  #38
David7.3's Avatar
David7.3
I had great success with Riff-Raff's FRX fuel kit, pain in the butt to install but after unplugging the back of the head's I am able to get air out better and increased fuel pressure with the black spring installed in the return valve on the filter housing. Made a big difference on my 7.3
Old Apr 26, 2018 | 11:14 AM
  #39
Mikefrfd's Avatar
Mikefrfd
Haven't seen riff rafts. Do you guys think a 99 fuel bowl would possible solve the issue. Or should I just e fuel it and call it a day
Red454sedgwick
Apr 8, 2018 07:24 PM
Rigormortise
Jan 7, 2015 06:39 AM
coltac
Apr 8, 2014 11:14 AM
strokin'_tatsch
96
Mar 3, 2010 09:01 AM
crazy4wdracer
Nov 8, 2009 06:32 AM
