Odd knock
Old Apr 6, 2018 | 01:06 PM
Red454sedgwick's Avatar
Red454sedgwick
Odd knock
Hey Guys I have a 95 f250. It knocks loud some times, then not so loud, and sometimes it goes away. When I pulled the injectors I found the o-rings were chewed up. bingo I got a new set of remans injectors from riff raff it.
It still knocks, but the injectors seemed to help. I still have good power. I'm wondering if the valve train can make a knock, or open to other Ideas. Truck is a manual with solid flywheel, with 313,000mi on it
Old Apr 6, 2018 | 01:13 PM
knottyrope's Avatar
knottyrope
what is fuel pressure at idle and WOT in 3rd?
What did you torque them too?
I did mine hot since one came loose after orings.
Also a manifold leak can sound like a knock
Old Apr 6, 2018 | 11:11 PM
Red454sedgwick
I'll check the fuel pressure but I don't think that is it I still have good power, It knocked right at start up, so I doubt a bolt is loose.
Old Apr 7, 2018 | 02:13 PM
Red454sedgwick
Well Fuel pressure might be the right track. 30psi at an idle and it doesn't take much throttle to put it over 100psi. it blew my hose apart on my gauge.
Old Apr 7, 2018 | 11:48 PM
fordman67's Avatar
fordman67
You should never see 100 psi. That's too high.
Old Apr 8, 2018 | 05:10 PM
Red454sedgwick
I took apart the pressure regulator and I had pieces of the old injector O-rings in it. Now it is at 65psi. It ticks instead of nocks now.
Old Apr 8, 2018 | 05:50 PM
97-psd's Avatar
97-psd
That seems like it helped quite a bit. Does the tick seem abnormal or just part of the PSD normal running
Old Apr 8, 2018 | 07:24 PM
Red454sedgwick
When its softly ticking it blends in with the motor well, when its loud it's very noticeable. I think my next step is to pull my valve cover and check my rockers.
Mikefrfd
38
Apr 26, 2018 11:14 AM
Zeropowerstroke99
Jan 24, 2017 06:33 PM
finallyo3gt
45
Jul 12, 2016 02:34 PM
Red454sedgwick
42
Oct 25, 2014 12:24 AM
crazy4wdracer
Nov 8, 2009 06:32 AM
