Glow plug help!
Old Apr 4, 2018 | 03:38 PM
Dieseloholic1's Avatar
Dieseloholic1
Awesome! Thanks again
Old Apr 4, 2018 | 03:39 PM
Skip1970's Avatar
Skip1970
u might want to talk to others to see about upgrading to the 7.3 idi glow plug controller tho as the old 6.9s burned them up allot, i run a manual switch on mine.
Old Apr 4, 2018 | 03:45 PM
Dieseloholic1
Thank you for the warning I'll upgrade as that was burnt out since I bought it I also have a button in the cab as well I want to use the key so.my grandfather doesn't over use that button
Old Apr 4, 2018 | 03:48 PM
Dieseloholic1
Is the 7.3 idi controller just like the older ones as far as hooking in
Old Apr 4, 2018 | 04:09 PM
tjc transport's Avatar
tjc transport
i ain't rite
no, they get wired differently.
if you go to the top of the page look for the Glow plugs, 87 thru 94, new style system stickie, and this will show you how to properly wire the relay and controller
Old Apr 4, 2018 | 04:29 PM
Dieseloholic1
Ok thank you
Old Apr 4, 2018 | 11:59 PM
Charmalu's Avatar
Charmalu
If you are going to up grade to the ZD-9 GP`s and Controller. Pick up a set of the GP harness for the 6.0 Ford Diesels.
Good thread here on what you have to do. You can get both Harnesses off E-bay for around $25. Be sure you get
both sides, some sellers sell only one side at a time for a high price.
https://www.ford-trucks.com/forums/1...-for-50-a.html
Charlie
Old Apr 5, 2018 | 12:01 AM
Dieseloholic1
Thank you I'll look into that
cornstar6207
Nov 27, 2017 11:10 PM
we287gn
Jan 4, 2015 06:42 PM
Eric Kropp
Sep 1, 2014 12:41 PM
beerman2therescue
Jan 31, 2008 05:55 PM
Greenlawnracing
Mar 11, 2007 06:02 PM
