Hi all I'm new here I have a 85 f250 6.9 It has 1109 autolites I was wondering if a previous owner changed the the glow plug harness I'm also looking for glow plugs that match the 1109s thank you for the help
Welcome. You should have Motorcraft ZD1s in your truck. Motorcraft and Beru glow plugs are the only ones that won't swell up and sieze in the heads.
If your glowplug harness was changed to the new style it would run Motorcraft ZD9s. The ZD1s have a spade style connector while the ZD9s have a bullet style connector.
If the Autolites are still in the truck you can safely remove them by spraying them liberally with PB Blaster for a week and loosening/tightening the glow plugs a litlle bit each day. This is how I removed glow plugs without damaging them. I think there's a thread with more tips but this worked for me.
The connetors must have been charged by the previous owner I'm not sure where I can find the proper connectors also I'll use the PB blaster I won't be doing that for a month or so I've still got snow at my place and thank you to everyone for helping a new guy
