stock boost levels
Old Apr 1, 2018 | 10:34 AM
3fordasho's Avatar
3fordasho
stock boost levels
Search says 18-20psi. I'm hitting 14 psi during a WOT 50-70mph run in 6th gear. Noticed some exhaust smoke coming from behind the turbo on this mornings cold start. Leaky stock up pipes I'm sure. Any urgency in addressing this now? Got lots of spring/summer projects that will require the truck, planning on pulling motor as next winters project (oil pan replacement among other things)
Old Apr 1, 2018 | 10:41 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
18-20 is pretty good for a stock system. Do a WOT from 3rd, then 4th and see what boost numbers you hit. 5th gear is meant for cruising really and the power is in 2-4 for the ZF6. When towing, I use 5th gear on flat land and slow rolling grades. Into the mountains the truck is in 4th gear towing up and 5th gear without a load.
Leaks are not efficient and should be addressed. Less dangerous on the exhaust side though than the intake.
Old Apr 1, 2018 | 10:42 AM
timmyboy76's Avatar
timmyboy76
It would be at the top of the list, if no egt gauge was present. Mine, for last 7.5yrs cant get more than 14#, and thats with the redline capped..no leaks either
Old Apr 1, 2018 | 11:28 AM
Colorado350's Avatar
Colorado350
I'm hitting 25 on the truck in my signature...no chip/tunes.
Old Apr 1, 2018 | 12:39 PM
3fordasho's Avatar
3fordasho
Just to be clear, I'm not getting 18-20psi at any point. 14psi max in any gear. Real question is will this low boost (from up pipe leaks/other boost leak) cause additional issues? There will be very limited use- 6-12 trips over the summer to the dump, gravel and firewood hauling. If I do pull the motor now it will be down when I need it the most. Motor pull scheduled for next winter to address all PM issues, replace oil pan and a few reliability upgrades.
Old Apr 1, 2018 | 08:15 PM
pirschwagon's Avatar
pirschwagon
The Service Manual says..... "Road Test - select appropriate gear to obtain desired engine speed and full load on engine (best accomplished climbing hill or truck fully loaded). Spec: MGP 15 PSIG Min"
So, a Stock truck should reach 15 PSIG Boost. There is no mention of a top number. 1 lb difference? or exaggerated readings? I would say Gauge or Sender.
You could make an inexpensive Boost Leak Tester to determine if there is a leak in the system. Most often, just "snugging" the CAC Clamps can overcome a pound or two.
Old Apr 2, 2018 | 06:48 AM
Tugly's Avatar
Tugly
Stock configuration is 17-18 PSI max. Anything over that and something has been tinkered with - like the wastegate actuator.
14 PSI is not good if it's there because of leaks and you're getting soot. I would urge you to at least get either an EGT gauge on the offending manifold, or both EGT gauges. This way, you can actually see what you are doing to your engine - and drive accordingly. If you find you can't tow the speed limit because of EGTs, then that will be your deciding factor.
Oh... my whole exhaust system from the block out has been replaced without pulling the engine.
Old Apr 2, 2018 | 07:11 AM
afmedic's Avatar
afmedic
I'm at 24 lbs with the red line capped. Was at 8-12 until I fixed my leaks. I don't have any tuning done, just intake and exhaust.
Old Apr 2, 2018 | 09:30 AM
Pocket's Avatar
Pocket
Exhaust leaks at the up-pipes will cause your slightly low boost number. The side effect is you will have slightly higher than normal EGT's. But on a bone stock truck you shouldn't be in danger. Exhaust leaks are very common.
Old Apr 2, 2018 | 09:35 AM
ZachinCO's Avatar
ZachinCO
I hit 16-18 with stock injectors(285k), upgraded wheel, AIS, bellowed up-pipes, 4" exhaust.
Old Apr 2, 2018 | 12:06 PM
Karlow's Avatar
Karlow
ZachinCo,
You may want to check for leaks.
Stock injectors 240K, 4" with wheel upgrade and 6 pos tune on 70hp is good for at least 25PSIG.
That is W/O upgreading to bellows. I can do that unloaded on a on-ramp with out trying too hard.
Old Apr 2, 2018 | 02:33 PM
ZachinCO's Avatar
ZachinCO
Originally Posted by Karlow
ZachinCo,
If I'm loaded I can hit 22, but I'm not a heavy foot. I probably should check for leaks anyways.
Thanks!
Old Apr 2, 2018 | 03:17 PM
brian42's Avatar
brian42
Veteran: Navy
It could also be the wastegate actuator getting old and not holding the wastegate shut at higher boost levels. Just my .02
Old Apr 3, 2018 | 11:10 AM
3fordasho's Avatar
3fordasho
So had some time yesterday and fabricated a boost leak checker and pressurized the intake to 15 psi- no leaks obvious on the intake side.
Ordered up-pipes this morning and about the order the turbo install kit required when R&R the turbo. What else becomes easy to do and a no brainer when the turbo and up-pipes are off?
Old Apr 3, 2018 | 11:35 AM
brian42's Avatar
brian42
Veteran: Navy
Things to do with the turbo out are:
- EBPV rebuild/replace/delete
- Rebuild the turbo
- Adjust/replace wastegate controller
- New turbo wheel
- install downpipe
- Passenger side fuel line (there is a tendency for it to rub through the metal line at the bracket about half way back).
Obviously nothing is required but these are all things I did when I had the turbo out for a bad oil leak a few years ago. I would definitely check the fuel line on the passenger's side for rubbing. I put some thin rubber in the bracket to minimize/prevent wear. I'm not sure how many miles are on your truck but a turbo rebuild is not expensive, just time consuming. I consider it an ounce of prevention. If you do it, make sure you have a 1/4" drive 8mm deep socket (12 point) or you won't get to some of the bolts. You're already doing the up-pipes.
None of these are required but sure are a lot more convenient if you already have the turbo out. These are all things that I did while I had everything out so I wouldn't have to go back there. Others will have ideas too but that's my .02
bad12jr
Oct 23, 2010 10:12 AM
blue66tang95f150
Jul 6, 2009 09:28 AM
MikeSDK
Jul 15, 2006 09:27 PM
FLASH 13
May 29, 2004 01:31 AM
Thumper4995
May 21, 2004 01:21 PM
