Specific Boost Question
Old Jul 4, 2009 | 12:25 PM
blue66tang95f150's Avatar
blue66tang95f150
I guess this thread is specificaly for boost and where it is lost, considering everythign else is working properly.
Something just doesnt seem right no my truck. I just put a boost gauge on my 95 with a 5 speed. The boost seems to climb really slow. There is only one gear I can get max boost. Here is how my truck buids boost in each gear, each reading is at 3k-3100 rpm.
First gear 6psi max, second gear 11psi max, 3rd gear 14 psi max, 4th gear 17psi max and 5h gear I can only get about 13. Does this sound right. Its like the rpm of the motor is faster than the boost spool up. It also throws a little black smoke each time till the bost hits about 2-3 lbs.
Where are all the places boost could be lost? I checked the end plate on my turbo and it seemd fine.
Anybody in Rogue River Or willing to let me drive their truck that you know is running properly. I have never driven another PSD other than a few I test drove.
Old Jul 4, 2009 | 02:27 PM
kawa's Avatar
kawa
Anybody in Rogue River, OR willing to let me drive their truck that you know is running properly. I have never driven another PSD other than a few I test drove.[/quote]
Now that was a pretty pointed request seeing as I am the only member in Rogue River, I have an auto so I don't know if you will get the same feel as with your manual, but I will tell ya that they sure as hell are not that low.
PM me.
Rog
Old Jul 4, 2009 | 04:43 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i fit is a stock 5 speed truck then those readings are perfect
Old Jul 4, 2009 | 07:01 PM
BlueMule's Avatar
BlueMule
That's what I was thinking too. With stock injectors and no chip you won't build much boost. and then with a manual you loose what you have every time you grab a gear.
Old Jul 5, 2009 | 08:02 AM
Talyn's Avatar
Talyn
Yea, I can barely keep any at shift points.
But when the turbo spools back up, its game time.
It feels like I get as much in 5th as I do in lower gears though.
No way to tell without gauges. And since I hate pillars, I have to come up with something more creative. Cause I don't care for gauges mounted on dashes either.
Old Jul 5, 2009 | 09:59 AM
BlueMule's Avatar
BlueMule
With a little work you can make a SouperDooty roof mount pod work in an OBS
http://www.itpdiesel.com/store.php/products/18017
Old Jul 5, 2009 | 07:45 PM
blue66tang95f150
PM me.
Rog
[/QUOTE]
I knew there was one person on here that was from rogue river, but I didnt know who. I probably could have looked in my PM history. Ill PM you for some contact info.
Well then I am not goign to worry about trying to find any boost problems. The next step for me is a down pipe i think. I think i am going to start looking into the IDM mod too.
Old Jul 5, 2009 | 08:06 PM
oldbird1965's Avatar
oldbird1965
I never got much boost stock eighter. After some mods it was better. The real test is to put a load behind it. I get a lot more boost that way.
Old Jul 5, 2009 | 08:37 PM
79f-250custom's Avatar
79f-250custom
i have a stock 97 f-350 PSD 5 spd with 307k miles on it and i can hit 15-18 psi in every gear and if i pin it in 5th gear going up a grade at 90 ish it will hit a little over 20psi. i do have an intake and a 3" dp to 4" exhaust. y can i get more PSI?
Mitch
Old Jul 6, 2009 | 09:00 AM
Talyn's Avatar
Talyn
To bad the CB will be right in the way for those. =*(
Otherwise the Roof mounted gauges there would be pretty pimp.
I'm just really not into the "main"stream sorta stuff.
I like to be different.
But people are already taking my ideas.
*******s.
Old Jul 6, 2009 | 09:28 AM
Brown Falcon's Avatar
Brown Falcon
I just got done putting in a 3" downpipe and did the IDM mod... I highly recommend both.
