C6 Automatic No Fluid - Ruined???
Old Mar 26, 2018 | 06:55 PM
Pheadrus's Avatar
Pheadrus
I have a C6 question. It's in my buddies old 71 Thunderbird. It had been stored outside and this week he had to move it. We're up in northern Canada so it's still pretty chilly out. He put a battery in it and got it running. He idled it for less than 5 minutes. Started it a few days later a couple of times for 2-3 minutes each time. Everytime the car stayed in park. He then went to move it and it did nothing when put into any gear so he turned it off. We pulled the tranny dipstick and it showed no fluid. Turns out the tranny had leaked over the winter. Did he wipeout the C6 by running it a couple of times at idle in park with little to no fluid? I don't want to fill it back up again if it's burned up.
Old Mar 26, 2018 | 07:06 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I would think the only way you will know for sure is to add fluid.
I also think the likelihood of damage at this point is low.
My own recent experience was with an AOD in an old F150 that had not been run in about 10 years. I got it started and discovered the truck would not move. The transmission fluid did not even show on the dipstick. Apparently there was a pan gasket leak and about 2 litres of fluid leaked out. Added 2 litres and the truck moved just fine.
Old Mar 26, 2018 | 08:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are two ways to know if it's burned up. One, put fluid in it and see if it works. The second way is to take the trans out and tear it down to see if it's damaged.
Old Mar 26, 2018 | 10:17 PM
Pheadrus's Avatar
Pheadrus
With the tranny leaking that much, it has to come out either way. I just didn't want him to waste the money on new fluid to fill it up and test it if the tranny is already likely pooched.
Old Mar 27, 2018 | 05:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
you should fill it anyway for two reasons.
#1: to see if it is still good. my bet is the trans is fine other than the leak.
#2: how are you going to find the leak if there is no fluid in it to leak out?
the problem may not be in the trans at all, it may be something simple like a rotted out cooler line.
Old Mar 27, 2018 | 08:49 AM
NotEnoughTrucks2014
If the problem is a simple leak, that does not become evidence that the transmission is pooched. In fact, a leak is one of the few things you can repair without removing the transmission from the vehicle. It most certainly does not have to come out without some further diagnosis.
Consider that the leak must have come from the lower portion of the transmission and not from an internal failure. This means something like a pan gasket or shifter shaft seal. Most of the fluid is carried in the torque converter and likely remains in the transmission. So, sacrifice a couple liters of transmission fluid, see if the transmission still works and find that leak!
Old Mar 27, 2018 | 10:12 AM
Eric Fullerton's Avatar
Eric Fullerton
The last C-6 I had could be counted on to need a bit of fluid after being unused for even a couple of months. The converter drains back, and it runs out the top, not really sure where, didn't care, just filled it each time it was drug out and put back in service. It was in an F-350, with a built 460, and more than once it was run up the road with less than a full charge of fluid, near as I can tell, it never hurt it a bit, when full of fluid, it would still do second gear chirp, and third gear scratch, when you were on the throttle. Finally sold it due to the fact that it was only used a couple of times a year, and it had to be recommissioned every time, (mess with the carb, fill the trans, etc.) Replaced it with the 1996 F150 4.9, 5 speed, finally fuel injection, and no leaks.
Old Mar 27, 2018 | 01:25 PM
Pheadrus's Avatar
Pheadrus
Thanks everyone for the knowledge and advice. When I looked underneath, it was dripping from the bottom of the bell housing but I couldn't see the source. We're in the middle of spring thaw and I have two herniated disc's so I haven't been able to get underneath to investigate further. I had just assumed it was the front seal that had dry rotted because the car has been sitting unused for most of the last 5-10 years. It drove and shifted fine last fall before it was stored.
Old Mar 27, 2018 | 02:00 PM
tjc transport
i ain't rite
it could well be the front seal, but it may also be a slow leak too. the C6 in my 88 diesel 4X4 only leaks about 1 quart every 500 miles.
LI250
Aug 25, 2011 05:41 AM
goldnickle
16
Mar 27, 2008 01:10 AM
dj8667
Jun 20, 2004 01:14 AM
eandaauto
Jun 6, 2004 02:15 AM
michaelbrainardatwor
Apr 2, 2004 03:07 PM
