L99 Lights pulsing??
Old Mar 26, 2018 | 09:09 AM
Supercab's Avatar
Supercab
My lights are litely pulsing with the engine is running-this was noticed in driving my truck in the dark after it had sat for a few weeks.
I had my ORIGINAL alternator rebuilt by a great, old fashioned, hometown auto electric shop about 4 years ago.
I believe the alternator has an internal regulator.
I know in my '65 Mustang when I installed a "reproduction" external regulator the lights pulsed wildly, whereas the lights in my truck pulse so litely it isn't super noticeable....
I'm going to run my truck to the shop and have them take a look......
Comments/ideas? Thanks Guys!
Old Mar 26, 2018 | 08:53 PM
pirschwagon's Avatar
pirschwagon
Check your connections at the Battery and GROUND. Often the Alternators do not ground well if they've become corroded at the through Bolts. Just using a ratchet and moving it loose/tight may relieve that. Personally, I always run a Cable for the Alternator Case to the Negative Battery Post.
use a DVOM to monitor the Output while it's pulsing. If the Voltage is also fluctuating, the Voltage Regulator could be the issue. It may have a bad connection to the Rectifier Bridge.
Old Mar 27, 2018 | 10:28 AM
Supercab's Avatar
Supercab
Thanks!! I'll check connections and grounds.....
brian1080
Oct 29, 2012 06:22 PM
afinepoint
Electrical Systems/Wiring
Oct 25, 2009 10:49 AM
j74250
Jul 6, 2009 06:55 AM
smileyracing
Oct 13, 2006 04:32 PM
bronzo
May 19, 2003 01:08 PM
