Pulsing lights and bouncing voltmeter
Old Jun 4, 2009 | 07:50 PM
afinepoint's Avatar
afinepoint
The dash lights, headlights - all lights pulse about three times per second. The dash voltmeter bounces in sync with the lights. The movement is small but noticeable.
I haven't started troubleshooting yet. The tachometer is steady but I think I can hear a slight pulse to the engine. This could be imagined.
The alternator was replace 20,000 miles ago. I haven't checked if the voltage regulator is integral with the alternator.
The weather has been rainy lately. I don't remember this occurring in dry weather. If it were a slight ground it seems the lights would just dim.
Ideas?
Reg
Old Jun 4, 2009 | 09:59 PM
Pkupman82's Avatar
Pkupman82
It could be your voltage regulator is going bad. I would start by checking to connections to the battery and alternator. It's amazing what havoc a bad electrical connection can make.
Old Jun 5, 2009 | 02:57 PM
afinepoint's Avatar
afinepoint
Plan to do that. It's been raining without a break for days and I don't want to mess with live wiring while standing in water.
Thanks for the reply. So the regulator is separate?
Reg
Old Jun 5, 2009 | 06:57 PM
Franklin2's Avatar
Franklin2
If this is the 2001, it's built in.
Old Jun 5, 2009 | 08:03 PM
afinepoint's Avatar
afinepoint
So the alternator which I just replaced has to replaced?
Old Jun 5, 2009 | 09:28 PM
Franklin2's Avatar
Franklin2
If all the connections look good, and the plugs that plug into the alternator are not melted, then yes, it would not be unusual to get a bad alternator if it's remanufactured.
Old Jun 7, 2009 | 09:04 PM
afinepoint's Avatar
afinepoint
The rain has gone, and so has the problem.
However this morning it was foggy and I noticed the greater the load on the alternator the bigger the swings of the needle. The headlights a little, my KC's more and the on board compressor running got the most movement.
This evening with sun and no fog - no moisture in the air I could not get the needle to bounce with either the headlights or fog lamps. At least I couldn't make out any movement.
Look like it's time to get out the spray bottle, flashlight and go hunting. It must be the alternator or a common ground. However the KC's and compressor grounds are not tied in any way to that of the OEM headlight circuit.
Reg
Old Oct 25, 2009 | 10:49 AM
afinepoint's Avatar
afinepoint
Replaced alternator with one from DB. Finally got to drive in rain (few hundred miles in fact). Bouncing voltage meter needle and pulsing light problem gone.
Anyone need an alternator? I have one that has one small issue.
Thanks for the replies.
Reg
78 PEB
1983 - 2012 Ranger & B-Series
27
Jul 10, 2016 10:32 PM
proudfrog
Jul 1, 2016 07:49 AM
flbmcman
Nov 15, 2011 09:32 AM
regidog
16
Feb 15, 2010 09:23 PM
dcaddi2
Oct 4, 2009 07:09 AM
