94 e350 351 Headers
Old Mar 22, 2018 | 11:05 AM
donovanracing's Avatar
donovanracing
94 e350 351 Headers
I did some searching here and also on the typical parts websites. I was not able to find a positive result on headers that are specific bolt in for the 351.
I'm not familiar with the ability of part interchange with the F Series, but the JBA shorty Headers listed for the F Series 351 look like a good match, but are not listed as a part for the E series.
I'm curious what headers people have used on their vans with the 302/351 based vans.
I would prefer to use a bolt in item, that would allow me to use the existing Y Pipe, or a stock replacement Y-Pipe.
Simply put, just replace the stock cast iron manifolds with steel headers. (I'm not concerned with air pump plumbing or EGR recirc system, it was removed already)
These are the JBA:
https://www.summitracing.com/parts/j...view/make/ford
These are the stock:
https://www.summitracing.com/parts/r...-350-econoline
Seem like a good fit, any feedback about fitment or alternative part options appriciated.
Thanks,
donovan
more looking found this thread: (looks like there is a reference to the truck headers here, but would still like a firm confirmation that these do indeed fit the E series)
https://www.ford-trucks.com/forums/1...8-headers.html
Old Mar 22, 2018 | 03:03 PM
richter roxs's Avatar
richter roxs
i used pacesetter shorty headers on my 1996 with the 5.8 , worked well truck pulls a little better .
Old Mar 22, 2018 | 03:46 PM
donovanracing
Thank you for the reply, your reply and with the thread I linked, sort of confirms my thoughts that the F-series headers will work on an E-series.
donovan
Old Mar 26, 2018 | 09:30 AM
baddad457's Avatar
baddad457
I also used PaceSetters on my 96 E150 with it's 351W. Passenger side cracked a couple years later in the collector and I replaced that side with Summit's house brand shorty header. Both were spec'd for the same year F150, As was the 3" stainless tailpipe I used in fabricating the full length 3" exhaust.
Old Mar 27, 2018 | 01:10 AM
vettex2's Avatar
vettex2
typically shorties don't improve power much
you might be better off by extrude honing the stock manifolds
YMMV
JeffNJF150
Mar 31, 2011 08:47 PM
4speed_thing
17
Jan 5, 2011 05:08 AM
78custom
May 19, 2003 11:04 AM
BlueTorpedo85
Exhaust Systems
Jan 29, 2003 10:47 AM
Kidd
Aug 19, 2002 08:33 PM
