Am I missing something? Sync 3 update
Old Mar 21, 2018 | 05:48 PM
Conrad Fleischmann's Avatar
Conrad Fleischmann
Old Mar 21, 2018 | 05:55 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
I don't have time to test this out for you guys but maybe give this a try:
  • On your Mac, hit 'command' and 'spacebar' at the same time
  • In the small box that opens, type 'Archive Utility' and hit 'enter'
    • It'll open the OS X archiver
  • Click 'Archive Utility' in upper left corner of screen and click 'Preferences'
  • In the dropdown for "Use archive format" change it to "Zip archive"
  • Close the app and then try downloading and unzipping the SYNC files again
This is just a guess. If it doesn't work, try the above steps and select "regular archive" instead of Zip archive, then try again. If both of these fail, then yeah, use the Extractor app as suggested above or install Windows.
Old Mar 24, 2018 | 05:41 PM
gascan's Avatar
gascan
I tried the update today and after 50 minutes my system is stuck on "Updating System Software...." Any ideas?
Old Mar 24, 2018 | 07:20 PM
CPal's Avatar
CPal
Mine did this the first time too. I let it go for over an hour (when working my truck runs 14hrs straight). Anyway I unplugged, shut truck down and restarted. Second time it was done in 20mins.
Old Mar 25, 2018 | 11:38 AM
GABAR's Avatar
GABAR
Originally Posted by BGMSPD
Download "stuffit expander" from the app store, it's free. download the zip file, click on it and chose open with and use stuffit expander.
then a window will show something like this
click on what looks like the play symbol to expand the file. You will then see this.
Select the three file that are shaded and copy them to you flash drive. I couldn't get it to work correctly until I used that program for some reason.
That app from the app store works so much better than the built in one on a Mac doesn`t it.
Just drag and drop the three things into the USB and you`re done.
Glad to hear it worked for you.
Old Mar 25, 2018 | 11:46 AM
GABAR's Avatar
GABAR
Originally Posted by 17350kr
I got it fellas. I just switched to a non apple desktop computer. It was so much easier. Unzipped one file and copied the three things to the USB and I'm sitting in my truck while it does the update. Thanks for the help and quick responses. Note to any one else struggling I'd Segway not using a Mac computer.
Glad to hear that you got it to work. Don`t give up on the Mac for the next update, once you download that extractor app, you`ll be shocked how quick and easy it is.
Again, i`m glad to hear that all is working well now for you.
Have a good day.
Old Mar 25, 2018 | 11:23 PM
Rockinfigs's Avatar
Rockinfigs
I just clicked on update software and it updated to ver 3.0 connected to my home wifi..i didnt have to download and use a USB drive.
Old Mar 27, 2018 | 04:25 PM
jims94vmx's Avatar
jims94vmx
doing by wifi question.....does truck have to be running? also downloaded to computer to put on usb if OTA doesn't work......
Old Mar 27, 2018 | 04:57 PM
Steve Lee's Avatar
Steve Lee
I had the engine on while it said updating software.. I waited few minutes n had to go inside the house so I shut off the engine went in n came back out few hrs later n checked it.. N it said software updated n verified it was ver 3.0
Old Mar 27, 2018 | 05:25 PM
Tunaahelper's Avatar
Tunaahelper
I did the update, but it said the system was already using the latest version. Guessing MY18's came with the updated version or perhaps late build dates.
Old Mar 27, 2018 | 09:03 PM
Spoojr's Avatar
Spoojr
I'm in the same boat. I have the correct file structure/naming, and I'm stuck just like you. I just left the USB in, and now it's been a couple days stuck here. I'm out of ideas...
Jhall244
Jan 29, 2019 02:37 PM
Spoojr
Mar 27, 2018 07:30 AM
Mike5737
Jan 13, 2018 06:31 PM
glsurratt
Jul 29, 2016 08:09 AM
pb34
2009 - 2014 F150
Dec 26, 2015 05:44 PM
