Dang, lower alternator bolt stuck on my 69 F250, 360 engine...
Old 03-17-2018, 06:47 PM
roguewave's Avatar
roguewave
roguewave is offline
Busted Knuckles
well this thing is not breaking loose, previous owner probally stripped the bolt head so I went ahead and bought a set sockets that work on rounded bolt heads. My 3/8 drive gun would not break it loose, this is after me useing a breaker bar. So I pulled out my 1/2 drive big gun, it would not budge. Dang, what next? Does that long lower alternator bolt go into a water jacket or something?
Suggestions?
Old 03-17-2018, 09:24 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is online now
Alternator bolt
Try to put a pipe wrench on the spacer between the block and alternator and rotate it, there may be corrosion between the 2 surfaces and if you can rotate it that may break the bolt loose. Or you can try a torch to heat the area where the bolt goes in the block.
Old 03-17-2018, 09:28 PM
Thipdar's Avatar
Thipdar
Thipdar is offline
Suggestions?
At this point, it sounds like you've already got a headache.
Should be two bolts, one pivot bolt & one to tighten in position when you're taking slack out of the V-belt.
Adjusting bolt goes to bracket, pivot bolt should go through a spacer, then gets set into the front of the block...
I have always been able to break it loose with a breaker bar.
Assuming the bolt won't move and that the head is rounded off, you might have to remove the head of the bolt, then bring the entire alternator assy. forward to slip it off of the pivot bolt. I'm not sure if there's enough room to do that. If you can slide the assy. off of that bolt, removing the bolt would then require a stud removing tool. If I could get it to this point, I think I'd try to break the threads loose by trying to screw the bolt in farther... any little bit of movement, then work the remainder of the bolt back and forth until it can be removed.
Old 03-18-2018, 06:57 AM
roguewave's Avatar
roguewave
Busted Knuckles
Thanks guys, I will be back on it today putting your ideas to work.
Old 03-18-2018, 09:31 AM
kenny nunez
Alternator bolt
The bolt may be frozen inside the alternator. Remove the adjusting strut and try swinging the alternator back and forth, If it turns out that the bolt is frozen in the alternator you may have to drill into the area where the bolt is and break the housing to get it off.
Old 03-18-2018, 10:24 AM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
A medium sized pipe wrench is your friend here.
Old 03-18-2018, 11:06 AM
67xr7kat's Avatar
67xr7kat
67xr7kat is offline
Re: Stuck alternator bolt
If you're dealing with the bolt that the alternator pivots on - drill a 1/8" hole in the aluminum alternator flange and another 1/8" hole in the steel, round spacer and soak with penetration oil, then heat.
Old 03-19-2018, 07:29 AM
roguewave's Avatar
roguewave
Busted Knuckles
I used a vice grip on the spacer and started working it back and forth, finally got enough movement to loosen the alt and change the belt. Not looking forward to the day I have to replace the alt. and remove that bolt, no way it’s coming out.
thanks all for the help!
Old 03-19-2018, 09:24 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
I went to pull an alternator in the junkyard, big 74 buick. The aluminum alternator had completely fused itself to the bolt. It wasn't stuck in the block. Heat, lots of heat is about all that will work, make several heat/cool cycles.
Old 03-19-2018, 09:28 AM
roguewave's Avatar
roguewave
Busted Knuckles
That makes sense, I think mine is the same.
Old 03-20-2018, 01:01 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
The best thing I've found to act as a penetrating oil is a 50/50 mixture of acetone and type F tranny fluid. Far better than PB Blaster or WD-40.
Old 03-20-2018, 01:54 PM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
X2 on that. Lube it every day for a week. Then give a try.
roller_steve
15
10-21-2023 09:33 AM
burnthelight88
11-18-2016 07:25 PM
jackny
12-23-2015 02:47 PM
pdqtimetrialer
03-29-2007 11:31 AM
Little Bro
04-15-2004 01:08 AM
Quick Reply: Dang, lower alternator bolt stuck on my 69 F250, 360 engine...
