Dang, lower alternator bolt stuck on my 69 F250, 360 engine...
well this thing is not breaking loose, previous owner probally stripped the bolt head so I went ahead and bought a set sockets that work on rounded bolt heads. My 3/8 drive gun would not break it loose, this is after me useing a breaker bar. So I pulled out my 1/2 drive big gun, it would not budge. Dang, what next? Does that long lower alternator bolt go into a water jacket or something?
Suggestions?
Suggestions?
on
Suggestions?
Suggestions?
Should be two bolts, one pivot bolt & one to tighten in position when you're taking slack out of the V-belt.
Adjusting bolt goes to bracket, pivot bolt should go through a spacer, then gets set into the front of the block...
I have always been able to break it loose with a breaker bar.
Assuming the bolt won't move and that the head is rounded off, you might have to remove the head of the bolt, then bring the entire alternator assy. forward to slip it off of the pivot bolt. I'm not sure if there's enough room to do that. If you can slide the assy. off of that bolt, removing the bolt would then require a stud removing tool. If I could get it to this point, I think I'd try to break the threads loose by trying to screw the bolt in farther... any little bit of movement, then work the remainder of the bolt back and forth until it can be removed.
roller_steve
15
10-21-2023 09:33 AM
burnthelight88
11-18-2016 07:25 PM
jackny
12-23-2015 02:47 PM
Little Bro
04-15-2004 01:08 AM
