tune up turned bad
well new plugs are in. i have spent so much time trying to remove the wiring harness. Reaching in behind the intake and back of the block, that I've been staring at the connectors this whole time. I feel comfortable enough to repin in place. I was going to create a drop Shield out of a paper plate. Cut a slice in the center and push connector through. Maybe even give it a little bit of a conical shape to catch all parts that might be dropped.
I did accidentally break another connector which was at the very end of the harness on the passenger side. It was crushed under the hood cylinder when lowering / closing the hood. Do you happen to know what connector that is too so I can purchase that?
thanks
thanks
