Electrical/Ignition Issues?
Old Feb 25, 2018 | 11:07 PM
1968greenf100's Avatar
1968greenf100
Hey there, new to the site, looking for some help with my truck.
1968 Ford F-100 Stepside.
Bought 2 years ago, fully restored, not original engine, 302 V8, but don't know brand, has lots of edelbrock parts on it.
Manual transmision, 4 gears, on the floor.
The issue: Starts up fine but after driving for a bit anywhere from 5-15 minutes, sputters out and dies. Won't restart, can't even push start, it sounds like it's trying to turn over but won't catch.
Some background: a year ago this same thing happened and it turned out to be a bad ignition coil. had it replaced and had no issue. Took it to a shop when the issue popped up again last month, they replaced the ignition switch and said it was all good but it still been cutting out on me.
My theories: I am not super skilled in auto repair but I know a little. My thought was maybe it might be an issue with spark plugs?
I am in the Hampton Roads area of VA, if anyone knows any good shops in the area that handle antique/custom vehicles.
Any help is greatly appreciated.
Thanks,
Gray
Old Feb 26, 2018 | 06:05 AM
GaryKip's Avatar
GaryKip
Does your dist. have the points and condenser system. Non-Ford condensers are famous for doing that. Fine China Quality, AKA, P.O.S.
Old Feb 27, 2018 | 11:11 AM
Filthy Beast's Avatar
Filthy Beast
Good call on the capacitator.....if you still have points and are adjusted right. Check to be sure.
Do you have the necessary tools here? A shop manual, timing light, vacuum gauge, DVOM, various tools and screwdrivers?
You could go broke if you keep taking her to a shop as these newbies generally don't know much about our older vehicles and their computers that tell you what the problem is won't work here. Best if you school yerself on the trucks.
Let us know what ignition system you have...we can troubleshoot issues from there without you throwing parts at her in hopes it fixes the problem.
If you don't know what the problem is, how can it be fixed?
And welcome to FTE
alans77crew
Dec 14, 2013 06:59 PM
1joshie1
Mar 5, 2011 05:44 PM
vortilon
Jan 6, 2010 10:40 PM
Melchiah
Sep 2, 2005 01:17 AM
powerstroker250
Mar 17, 2003 07:31 AM
