302 ignition HELP
Old Mar 2, 2003 | 08:41 PM
powerstroker250's Avatar
powerstroker250
302 ignition HELP
I know I know it's not a truck but a 1985 Lincoln Towncar. The problem is I only get a spark out of the coil when the key is turned on and then when turned off. There is no spark when the engine is cranking. The coil and TFI module have been replaced and the balast resisitor bypassed. This is my dad's car and I need to get it fixed for him. Any and all ideas are welcomed and appreciated.
Thanks, Les
Old Mar 2, 2003 | 09:15 PM
pfogle's Avatar
pfogle
302 ignition HELP
try replacing the pickup in the dist itself...... you may also want to make sure that any and all ground wires are in tact... it could also be a problem in the ignition switch.
Old Mar 3, 2003 | 06:39 AM
powerstroker250
302 ignition HELP
I forgot to mention that the ignition switch was also replaced by my father but I think the problem started before the switch was replaced. I'll ask him. As far as I know ALL the parts that were replaced were replaced after the problem occured. Anymore ideas?
Thanks, Les
Old Mar 5, 2003 | 05:02 AM
55forder's Avatar
55forder
302 ignition HELP
You get spark when the key is turned off? Hmmmmm.
I would think that its a problem with the ignition wiring.
Old Mar 5, 2003 | 05:38 AM
macguyver's Avatar
macguyver
302 ignition HELP
An '85 with TFI? Boy have I been out of it for a while. I thought TFI's were newer. Anyway, sounds like ignition primary circuit. Either pickup coil or control module. The spark when the key is shut off says that the coil is getting juice and the magnetic field in the coil is collapsing (like it does every time it fires) and it sparks once. This is normal. What's not normal is the coil isn't getting a signal to fire in time with the engine.
Also, around that year there could be an extra ground wire that grounds the ignition module. Look for a square grey connector with a black wire near the solenoid/battery area. If this wire is corroded or broken you won't get spark.
Hope this helps.
Greg
Old Mar 5, 2003 | 07:40 AM
powerstroker250
302 ignition HELP
Thanks for the responses, I haven't had time to do anything yet but hope to get to it this weekend.
Les
Old Mar 9, 2003 | 10:33 PM
Merlin 306's Avatar
Merlin 306
302 ignition HELP
My '89 Lincoln LSC had a similar problem, the wiring harness that plugs into the switch came loose. Would fire when cranking then when the key was released it would shut off. Cleaned the connection and secured the plug so it wouldn't come off again, problem was solved.
Old Mar 10, 2003 | 07:45 AM
powerstroker250
302 ignition HELP
I've been too busy to do anything yet but my dad got started on it and said all the insulation or coating just fell off the pickup when he touched it. Will let you know how it turns out.
Thanks, Les
Old Mar 17, 2003 | 07:31 AM
powerstroker250
302 ignition HELP
Thanks for the help. The problem was in fact the pickup in the distributor. It runs great now!
Thanks again, Les
Aircraft Tech
Jun 23, 2016 10:50 AM
kfain71
Jan 25, 2016 11:41 AM
Mark14
15
Feb 26, 2015 09:57 PM
almonyspm1
Dec 11, 2012 12:56 PM
hummertires
Dec 31, 2007 12:34 AM
