what is this?!
Old Feb 25, 2018 | 10:09 AM
arapf's Avatar
arapf
what is this?!
Pulled out the instrument cluster of my '68 F250 and saw this, disconnected/severed by a previous owner? Anyone know what it is?
Old Feb 25, 2018 | 10:43 AM
Tomahawk's Avatar
Tomahawk
The red/blue wire goes from the key switch to the starter solenoid. I snipped the red/blue wire in half, added female spade lugs and plugged it into my clutch switch so the clutch needs to pushed in before the engine will start. It would work the same way for an automatic. You would need to be in P or N before the engine would start.
Old Feb 26, 2018 | 05:49 AM
GaryKip's Avatar
GaryKip
arapf, does your NSS work- Do you have to be in park or neutral to start the truck?
Old Feb 26, 2018 | 11:21 AM
arapf's Avatar
arapf
this is starting to make sense now that I think about it. my truck was an automatic originally and the previous owner converted it to a 4spd manual. Would it be reasonable to assume that this is disconnected because of that conversion?
Old Feb 26, 2018 | 01:28 PM
DisneysPatB's Avatar
DisneysPatB
Yes, that pigtail would go to the neutral safety switch.
Old Feb 27, 2018 | 01:26 AM
GaryKip's Avatar
GaryKip
Now the plot thickens!!!
Old Feb 27, 2018 | 09:45 AM
Thipdar's Avatar
Thipdar
A "Clutch Saftey Switch"... I like that concept... but it needs an emergency override
Old Feb 27, 2018 | 10:58 AM
351Cleveland C4's Avatar
351Cleveland C4
I have that same plug dangling around in my truck. Always Wondered what is was for! I for one don't like neutral/clutch switches. I find them to be a nuisance.
Old Feb 27, 2018 | 01:28 PM
Thipdar's Avatar
Thipdar
Take the electrical tape off.
You may find that there are only two wires there, each looping from one pin on that plug back to another pin on that plug.
Normal setup according to my 1970 wiring diagram.
One circuit is for the Starting circuit (Ignition Switch to Starting Motor Relay), the other provides power for the Reverse Switch and the Windshield Wiper system.
Likely that nothing was "disconnected".
Re-wrap with electrical tape when you're done.
Golden1991
31
May 30, 2018 08:04 AM
Shayne7.3diesel
Feb 5, 2013 02:34 PM
86bigred
Feb 21, 2009 07:47 PM
jchilcot
Aug 24, 2008 08:48 AM
dstevenson
Electrical Systems/Wiring
Jun 1, 2003 10:35 AM
